Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-02-2011, 06:24 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Trans Slipping
My trans was ok till about 3 to 4 months ago. I put in some 80w 90 and now anytime I get on the gas, half the time it will do nothing but rev rpm's and not HP. Did I use wrong gear oil?
Or is it a bad tranny all together?
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
Old 03-03-2011, 03:36 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Trans Slipping
Clutch, assuming 'HP' means that the car isn't actually moving when press the gas.
So it was rebuild and now you're having problems already? I'm confused between this post and your last one.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-06-2011, 08:45 AM
Re: Trans Slipping
Still hasn't been rebuilt yet till I get the money together. Just wondering if it could be the clutch cause I just replaced it about a yr and 1/2 ago. But ya when I get on the gas it slips real bad. Doesn't do it bad at first guessing till the trans heats up and until that day I put more gear oil in it.
I see what you mean by being cunfused when I said he did the rebuild for me. Was a typo, ment he is going to. Sorry
Old 03-06-2011, 10:19 AM
Scrapper Scrapper is offline
AF Premium User
Re: Trans Slipping
shure sounds like you need clutch and pressure plate again. when you changed it last did you look at fly wheel when you changed it to see if it was blue from sliping? if was blue that's probley your problem now since it's sliping already?
Old 03-06-2011, 04:40 PM
Re: Trans Slipping
When we rebuilt the motor, we put in a new Exedy plate. But I have been having problems with the trans since I put car on the road. But didn't think it was the clutch and pressure plate since they were new.
Old 03-07-2011, 01:57 PM
AF Premium User
Re: Trans Slipping
so are you saying it's not sliping now?
Old 03-13-2011, 01:42 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Trans Slipping
If its slipping then the clutch is gone. Nothing you can do but pull the tranny and see what happened.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
The Following User Says Thank You to SilvrEclipse For This Useful Post:
Cavalier9696 (03-13-2011)
Old 03-13-2011, 07:58 PM
Re: Trans Slipping
Ahhhh just put that clutch in. Can't remember if I had a warrenty to it or not. I still have receipt for it. Thanx guys.
Re: Trans Slipping
Naw it's still slipping scrapper
Old 07-03-2011, 02:12 PM
Re: Trans Slipping
K fixing to buy a new clutch kit. What would be best? Just stock or stage 2 or 3 since IM running turbo now? Just making sure to see how much I can save on buying the kit. Auto zone has the stock kit for $230 but i have seen some stage 2 and 3's for only $200 more. Like here. http://www.andysautosport.com/mitsub...c00005318.html
Old 07-04-2011, 11:53 AM
AF Premium User
Re: Trans Slipping
i would get racing clutch and presure plate since you have the 350 in it and check summit or jegs to get a good one.
good luck.........
Last edited by Scrapper; 07-04-2011 at 11:56 AM. Reason: i'm answer for wrong car.
1996 Express Trans slipping Broker-Ron Express | G Van 3 03-12-2006 10:49 PM
'95 Auto Trans Slips how fix rdague Escort 6 06-17-2004 09:05 PM
Trans Slipping chevyguy1995 Lumina 10 01-19-2004 11:45 AM
Trans. slipping? frost-nc Durango 2 01-14-2004 07:44 PM
98 Taurus Trans slips intermittenly lencasady Taurus | Taurus Wagon 9 11-28-2003 11:09 AM
