Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-01-2011, 08:25 AM
privatepilot03 privatepilot03 is offline
Slow upshifts after battery disconnect
Hello All,
I went through the intake manifold replacement fiasco this past weekend on my 2003 Montana. Along with the gasket repair, I replaced the spark plugs. The job is complete but I have 2 problems.
The first and primary problem is that the transmission is slow to upshift since the repair. It's noticeable on all upshifts, but most notably on the 1-2, 2,3 shift. I had the battery disconnected for the duration of the project but did not make any changes that should have affected the operation of the transmission that I'm aware of. Any ideas?
Secondly, there is a small solenoid with a vacuum line attached to it between the throttle body and the EGR solenoid. It has an electrical connector and a vacuum line that goes to a tee right behind the throttle body. I see an open port on this solenoid that pulses air when the engine is running but cannot find a hose to connect to it (and don't remember removing a hose). Any ideas what this is or if it should just be capped?
I have no CEL or warning lights. The van seems to run fine with no loss in power or hard starting etc. Seems like the repair went really well but the transmission thing scares me a little bit.
Thanks in advance
Old 03-01-2011, 06:47 PM
kornjulio kornjulio is offline
Re: Slow upshifts after battery disconnect
The solenoid you discuss is the EVAP canister purge solenoid/valve. Yes, there is a vacuum line that goes to it. Maybe capping it will work, but I'd find the end of the hose - it's gotta be there somewhere. If it's not fixed & operating properly, I forsee a CEL at a minimum - possibly driveability symptoms, as well.
As for the shifting, I could be wrong but I believe our 4T65e tranny is a learning or adaptive tranny. The shifts should get better as you drive it. Case in point: I replaced the shift solenoids in mine. Didn't disconnect the battery, but it still shifted like crap initially. Then it got better & now shifts better than ever.
2000 Venture - repairs to date:
LIM gasket, water pump, wiper park position, front wheel bearings, rear wheel bearings, flickering lights, blower motor resistor, door speaker corroded, rear hatch handle, rear wiper motor, front struts, busted sway bar, LCA bushings, hard shifting tranny (new solenoids!)
Old 03-01-2011, 06:50 PM
Thanks. I'll look for the evap line and give the trans a couple days.
Regards.
Blazer stalls after battery disconnected! Ricky128 Problem Diagnosis 2 05-09-2007 12:33 PM
1997 LaSabre radio doesn't work after battery disconnected - not anti theft problem. A. J. Clark LeSabre 5 11-30-2005 09:48 PM
98 accord radio locked up after battery disconnect cyalookin Accord/TSX/Accord Hybrid 2 07-01-2005 09:34 AM
99 Expedition getting bad mpg after battery disconnected joe_charles Expedition 0 10-20-2004 05:51 PM
