Old 02-28-2011, 03:27 PM
travis2822 travis2822 is offline
Send a message via Yahoo to travis2822
99 Blazer 4.3 4WD Rough idle weak choppy accelaration
Truck has been running fine until today. I drove about 10 miles on the highway. I got off onto the ramp into the intersection. I felt the truck start to stumble a bit. Put it in nuetral and i could feel a rough idle. The light turned green and I put it into drive and had very little accelaration. When I get to about 20mph acceleration is a little bit better but still rough.
There is also a rotten egg smell that started coming from my truck.
I also hear a rattle located in the middle where the rear drive shaft connects. Rattle goes away upon accelaration.
Thanks for help.
Tune up was this summer.
Below are the codes Autozone pulled for me.
P0300
P0452
P0142
P0453
No light until today. Blinks while accelerating and is solid at idle.
Thanks again.
Old 02-28-2011, 03:55 PM
viggy58 viggy58 is offline
Re: 99 Blazer 4.3 4WD Rough idle weak choppy accelaration
start with checking your fuel pressure...
make sure the engine is nice and warm when you do.
any check engine light?
when was the last time you had a tune up?
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
The Following User Says Thank You to viggy58 For This Useful Post:
travis2822 (03-03-2011)
Old 02-28-2011, 04:01 PM
Tune up this past summer.
I'll check fuel pressure although pump was also replaced this past summer.
Check Engine light was not on until today and it started blinking.
Old 03-01-2011, 07:18 AM
The rattling noise is coming from the catalytic convertor. Does that mean it is bad? Could that cause the code P0300 and performance issues?
Old 03-01-2011, 07:47 PM
old_master's Avatar
Advisor/Moderator
P0300 is usually caused by secondary ignition failures: Distributor cap, rotor, plug wires, and spark plugs. When the SES blinks on acelleration it means the engine is misfiring. Misfire can cause a raw fuel odor. These engines can be very fussy when it comes to secondary ignition parts. Aftermarket parts usually cause more problems than they're worth, stick with AC Delco parts. A rattling converter can cause a lack of power. If the insides are loose, it needs to be replaced. Fuel pressure is critical on the 4.3L and again, aftermarket parts don't make the grade. Ignition ON, engine OFF, fuel pump running: pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the pump shuts off.
When it comes to DTC's, (diagnostic trouble codes) always diagnose and repair the first DTC that is retrieved, clear the codes from memory, and perform a drive cycle, http://www.obdii.com/drivecycle.html If the SES light comes on during or after the drive cycle is completed, repeat the steps above until the SES light no longer comes on. Any DTC's that appear after the first one, can be caused by the first one, that's why they need to be diagnosed and repaired in order.
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
Old 03-03-2011, 04:33 AM
Thanks for the help. I changed the plugs, wires, distributor cap, and rotor with AC Delco parts and my truck is running like a champ again.
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
2002 blazer, 4.3 vortec rough idle obadious Problem Diagnosis 0 11-27-2006 09:21 PM
91 4.3 v6 rough idle at cold start tomfree99 Problem Diagnosis 0 11-01-2006 10:13 AM
overheated 4.3, now rough idle timothyhampton Blazer 4 05-27-2006 02:17 PM
