Old 05-26-2006, 05:29 PM
timothyhampton timothyhampton is offline
overheated 4.3, now rough idle
Mom blew the water pump in her 98 Blazer and overheated the 4.3 engine. It always had a bit of a rough idle but now it's even worse. The guy who replaced the pump ran the codes on it and it came up with cyl #4 misfire. She had someone else replace the plugs, cap, rotor and wires. It still idles pretty bad. He said maybe a blown head gasket. I had a quick look at it today and checked the compression on the #4 cyl and it seemed fine with no leak down. The plug is gapped correctly and is the correct AC delco replacement. What should I check next? I'm hoping she didn't cook the intake manifold gaskets and cause a vacuum leak! Thanks Guys
Old 05-26-2006, 11:59 PM
OverBoardProject OverBoardProject is offline
Banned
Re: overheated 4.3, now rough idle
Please take the time to do a full compression test and get back to us.
Also look for any vaccum hoses that aren't hooked up while your at it.
I hope that it's a vaccum leak.
Old 05-27-2006, 12:57 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Might also be the #4 injector.
Reset the computer by pulling the negative battery terminal overnight and see if things come back.
It could be the computer.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-27-2006, 08:13 AM
Thanks Guys, I'll reset the computer and do a full compression test of all the cylinders as well check out the vacuum hoses. Tim
Old 05-27-2006, 02:17 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
These engines do not take overheating well. I have heard stories ranging from blown head gaskets, to totally bent up valvetrains not to mention what happens when what remaining coolant mixes through gaskets into engine oil...
I am with the other guys, do a compression test and a leakdown test if possible. If you haven't already change oil and filter like, yesterday. Change oil and filter again in 500 miles. You might have a valve stem contaminated with coolant that turned into a blob at one end, not letting it open fully or close for that matter. SO many things can go wrong after overheat. I wish you luck.
