Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-28-2011, 03:25 PM
bg00se bg00se is offline
93 Thunderbird will not start
After my car sits for a long period of time it does not always start. I have to continue to start the car and eventually it will turn over. Other times, the car will drain the battery. Not sure what is wrong with it.
Old 02-28-2011, 05:35 PM
rhandwor rhandwor is offline
Re: 93 Thunderbird will not start
Use a 12 volt test light put it on the coil negative. Have someone else crank the engine if the light doesn't blink change the pickup in the distributor. If it blinks change the module.
Old 02-28-2011, 05:38 PM
97Bird's Avatar
97Bird 97Bird is offline
Welcome to the forum bg00se. There is always a drain on the battery due to the electronics in the car including the computer, clock, etc. This means if your car sits for a long time you will eventually have a dead battery, unless you keep a maintenance charger on it. A Battery Tender or BatteryMinder are two good chargers that won't overcharge your battery.You didn't say how long the car sits without you starting and charging the battery. I'd have the battery load tested to see if that is your problem. Cold weather and an old battery don't mix well!
The Original 97Bird
Old 03-01-2011, 07:44 PM
I have a brand new battery so that cant be the problem, also when my thunderbird is not warmed up, sometimes it has trouble accelerating and will often stall out..im not sure if these two problems are connected.
Old 03-01-2011, 08:39 PM
Does the engine turn over and won't start or does it take a long time to start?
2000 GMC Sonoma Will Not Start Without Starting Fluid aserapiglia General Discussion 10 01-29-2011 10:27 AM
Will not start (sort-of randomly) caffeineaholic Caprice 7 08-04-2010 08:13 PM
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
Winstar will not start sometimes bwagner61 Windstar 5 02-21-2010 01:04 PM
89 Thunderbird will not start when hot just4ebaybuy Thunderbird 4 10-11-2005 03:55 PM
