Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 02-28-2011, 10:57 AM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
'98 Intrepid 2.7 bad computer
Hi, guy dropped off a 1998 with a 2.7, said he was driving down the highway and it died, turns over, but no fire. When I got it two of the ignition fuses were blown, can't remember which two right off hand, and I don't think the fuel pump was coming on, after replacing those fuses the pump runs, but it's not getting spark or pulses to the injector. I know I had a similar problem with an '03 Caravan and I had to check like C59 or something on the PCM to see if was supplying ground coming out of the computer. Is there a similar check for this computer?
Old 02-28-2011, 05:25 PM
82Stang 82Stang is offline
Re: '98 Intrepid 2.7 bad computer
things I would check;
-timing belt
-ignition control module
-coil
-fuel filter
-ignition switch
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 02-28-2011, 05:32 PM
bigj-dog's Avatar
Timing belt is good, compression wise anyway. This car has individual coil on plugs, is there ignition module for that setup? Fuel pressure is good, so I'm assuming filter is ok, and ignition switch turns on the fuel pump, so I'm guessing it's ok too. Currently I'm not getting pulse at coils, and the injectors aren't firing. Thanks for the ideas.
Old 02-28-2011, 05:39 PM
There is an ignition starter switch for that, whether it has any relevance or not, don't know. But another thing too, I think this model has a fuel cutoff switch somewhere.
Rodney Dangerfield
Old 03-02-2011, 05:01 PM
bigj-dog's Avatar
The owners just bought it, so after my preliminary checking, I told them to call the dealer where they bought it. Didn't want to dig too deeply if they'd warranty anything. Hopefully it won't come back.
Old 03-03-2011, 12:05 PM
We've all been there at one time or another. It'd be interesting to know what it ends up being.
Rodney Dangerfield
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
2000 Intrepid 2.7 swap to 3.2? Pete555 Intrepid 5 09-10-2009 11:54 AM
Intrepid 2.7 to 3.2 swap Bikefreak Intrepid 3 01-17-2005 03:05 PM
99 Dodge Intrepid 2.7 misses at idle reno605 Intrepid 2 12-09-2004 03:47 PM
1999 Dodge Intrepid 2.7 Engine Diagram pipegirl9 Intrepid 1 09-17-2004 12:01 AM
