Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 02-26-2011, 05:02 PM
quackshot quackshot is offline
2001 Kia Sportage Vibration
I replaced the center drive shaft support bearing on my 01 Kia Sportage and now I am getting a vibration around 25 mph any suggestions
Old 03-01-2011, 08:16 AM
LMP's Avatar
LMP LMP is offline
Re: 2001 Kia Sportage Vibration
is this a 2WD or a 4WD ?
..ANy vibration in the drive shaft system make one think of a failed universal joint in the first place... in the absence of other info.
What was the reason for replacing the "center drive shaft support bearing".....which I'm not sure to identify positively....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 03-01-2011, 05:51 PM
This is a 2 wheel drive. The center bearing was replaced because it was making a grinding noise. The u joints move freely and dont seem to be binding but I guess they could still be bad
Old 03-01-2011, 08:43 PM
LMP's Avatar
LMP LMP is offline
Not familiar with the 2WD. ....is the longer driving shaft split in two requiring that center support bearing?....which I'm borne to understand...if that is the case, are the 2 sections built with a collapsible section..
Old 03-01-2011, 08:59 PM
They are similar to this
Scroll down to page 7
http://ww2.justanswer.com/uploads/jo...3443_drive.pdf
The Following User Says Thank You to quackshot For This Useful Post:
kris (03-04-2011)
Old 03-07-2011, 03:27 AM
LMP's Avatar
LMP LMP is offline
OK...that is like the 4wd....with a telescopic section..this is where you replaced a sleeve bearing...so...if you lift and rotate a rear wheel can you see any wobble of the driving shaft...? Was there a vibration already before you changed the sleeve ? any possibility the driving shaft had contacted something in off road driving ?
Old 10-26-2014, 12:40 PM
ZorgEntity ZorgEntity is offline
I was just out in the garage looking at my new one. I notice that in the housing there is an inner portion that in slightly smaller. I was wondering if you pressed the bearing into this section before you slide the assembly onto the shaft. I imagine if you place the bearing in the outer loose portion of the housing it would develop a wobble. I won't be completely sure though until I take my old one off and inspect it. I'm going to see where the seals fit in the housing first also.
01 Kia Sportage 4x4 DEAD No start No power Needs jumpstart everytime HPYUNBDAY Sportage 2 07-27-2011 09:45 PM
2000 Kia Sportage died on fwy. Will Turn over but not start...HELP over_kia Sportage 3 10-16-2010 03:11 AM
2001 Kia Sportage driveshaft problems KPyle Sportage 3 02-19-2010 07:56 AM
2001 Kia Sportage catalytic converter problem? Leoc001 Sportage 4 12-08-2005 10:14 PM
2001 Kia Sportage Bezel radio removel Helixrider Sportage 1 12-07-2005 03:26 PM
