Go Back   Automotive Forums Car Chat > Racing > Formula-One
Old 02-26-2011, 10:04 AM
igor@af's Avatar
igor@af igor@af is offline
Your friendly AF Admin
Send a message via ICQ to igor@af Send a message via AIM to igor@af
The new Williams gearbox and rear end
This is rather interesting:
The Williams FW33 has the lowest rear end (2) of all the new cars - lower even than Red Bull's RB7 - due to very compact packaging of the gearbox and differential. So low are they in fact that the driveshaft (3) angle is the greatest ever seen, at around 14° (6-7° is normally considered the maximum limit for this component). Williams spent a lot of time developing and testing this solution before introducing it to the new project. Indeed, the whole rear of the FW33 is innovative - witness the unique pick-up point for the suspension's top wishbone, mounted directly on the central rear wing pillar (1). Williams have also followed the trend for a pull rod rear suspension layout (4) for 2011. Only Ferrari, Sauber (with the Ferrari gearbox), Virgin and HRT have kept a push-rod layout.
Courtesy Formula1.com
I wonder how they managed to make the 14 degree driveshaft angle work.
Welcome to the Revolution
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
1995 Dodge 1500 rear end problems alley30577 Ram Pickup | Ram SRT10 2 02-19-2010 09:37 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 09:10 AM
Rear end noise fastlane85023 Mustang Problem Diagnosis 4 11-29-2009 07:39 PM
NEW MEMBER caprice questions rear end. cause4panic Caprice 7 02-28-2005 02:07 PM
