Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-25-2011, 10:16 PM
tabby24 tabby24 is offline
Question 00 lincoln ls Annoying beeping and steering wheel controls and horn not working, Please Help!
I have a 00 ls v6. When I first start the vehicle the is a beeping sound. It beep 5 times in a row and then pauses for a few seconds and repeats the sequence 5 times. I was told that this could be an airbag problem and my airbag light is not working. Also, my horn radio and cruise controls are not working on my steering wheel.
Please help. I simply can not afford 200 just to have the car looked at. Thankyou
Old 02-26-2011, 11:56 AM
gcwimmer gcwimmer is offline
Re: 00 Lincoln ls Annoying beeping and steering wheel controls and horn not working, Please Help!
It sounds like the clock spring in the steering column is failing, a common problem in the Lincoln LS. It is about $130 part and a relative easy DIY replacement.
The Following User Says Thank You to gcwimmer For This Useful Post:
tabby24 (02-27-2011)
Old 02-26-2011, 03:33 PM
joegr joegr is offline
Re: 00 lincoln ls Annoying beeping and steering wheel controls and horn not working, Please Help!
Yes, a new clockspring may fix all those problems except for the SRS light being burnt out.
Old 02-27-2011, 08:17 AM
Thanks. Would you happen to know how to replace the light?
Old 02-27-2011, 12:37 PM
Yes.
Remove the instrument cluster.
http://deneau.info/ls/s6x~us~en~file...tm~gen~ref.htm
(Don't worry about saving the parameters since you will be putting the same cluster back in.)
Change the bulb.
steering wheel radio controls carsarefunyes Grand Prix 1 11-11-2010 01:37 PM
Steering wheel controls and horn not working! Yorch Montana/Montana SV6 5 08-11-2010 11:02 PM
300M steering wheel shaking and pulling right?. sandrav0312 300M 1 08-07-2010 04:47 PM
climate controls will not work please help brtnsteve Caravan | Voyager 1 12-17-2007 09:30 PM
Steering wheel controls and Pioneer HU threedd97 Car Audio 3 12-15-2004 12:54 PM
