Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-25-2011, 08:17 AM
dessicated dessicated is offline
90 civic hatchback wont start
ok i have a problem....i have a 1990 honda civic hatchback and it will not start...NO turn over or nothing...i have replaced altenator, starter, ignition lock/key, ignition wiring, battery, all brand new grounds and a new distributor....and it still wont start....also i can pop the clutch and it will start up fine but other than that it wont...can anyone help?
Old 02-26-2011, 04:39 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: 90 civic hatchback wont start
quite the interesting problem you have....
with you being able to pop start it fine, i would say the problem lays in the starting system...
i would first test the starter, out of the car, to see if the problem is there...
then i would test the ignition switch inside the car, and with a multimeter, follow the path the signal SHOULD take to deliver power to the starter to start the car... where you stop seeing power... the break is somewhere in that area...
good luck
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
Beloved 84 Accord HatchBack Wont Start tdallenkk Accord/TSX/Accord Hybrid 1 07-13-2004 09:40 AM
93 esort hatchback wont start poling2482 Escort 1 06-08-2004 03:28 PM
