Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 02-23-2011, 04:11 PM
wtp1 wtp1 is offline
Unhappy 2004 Monte Don't Start
We have a 2004 Monte Carlo 3400 engine that won't turn over. Won't even try. Security light wasn't on but was told the security will shut the system down. Put new battery in and tried new ignition. Went through the learn procedure. turn the key and everything seems to work but turn to start and theres nothing, don't even try start. Don't even hear the fuel pump. Jumped the starter and it will turn over over that way but won't start. Guessing cause theres no fuel. ran fine and went out in the morning and nothing. Any ideas?
Old 02-23-2011, 07:42 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Re: 2004 Monte Don't Start
I moved your thread in this forum as it would be more appropriate and get answered with the vehicle type.
Now I have a few questions about your issue before I can even begin guessing the problem.
1. Is this a new problem or something that came with the vehicle from date of purchase?
2. You purchased new ignition, but did you have the starter checked?
3. Does the vehicle come with Burg alarm? If so, did you purchase with it or did you install a new alarm?
Please provide more information about the vehicle and it will only help you to get an answer. Start with the above for now.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 02-23-2011, 08:09 PM
Thank You
New, Everything was fine untill Friday morning
The starter turns over if you hook direct power to it but will not start it
No Alarm system
All fuses and relays are good
Old 02-23-2011, 08:24 PM
DVSNCYNIKL's Avatar
R.I.P. DAD 3/25/11
Based on your answers, I can provide some suggestions, but again, without more info it will be difficult, at least on my end.
Sounds like you need to check the following:
1. You said when you give it a boost, it turns over but doesn't start. Could be a bad alternator. If it can't charge the battery, it will never start.
2. Check to make sure fuel injector is clean. Could be possibility of not staying on.
3. Make sure starter is getting power. You may need to get an ohm meter to see(Not sure how to do this).
As you can see, the possibilities are many that can only be deduced by trial and error. See what works and doesn't and report back.
Old 02-24-2011, 02:44 AM
something has to be disabling the system. The fuel pump is not running, and theres no spark. the starter works if you jump it. when you turn the key to acc everything works. turn the key farther to engage starter and theres nothing while holding the key in the start position. just like the battery is disconnected.
Old 02-24-2011, 12:09 PM
PROBLEM FIXED:
On the drivers side below the air cleaner theres a wiring harness. Took the air cleaner out and there were like 5 wires that a mouse had chewed through. I suppose they went up in there looking for warmth. One of them wires went to the starter. Thanks for the help.
Old 02-24-2011, 01:28 PM
inafogg inafogg is offline
wtp,good to hear you found problem thanks for sharing the fix
was car sitting for awhile or just over night
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 02-24-2011, 05:58 PM
Just over night
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
2004 Monte Carlo SS Question 2000blazerls Monte Carlo 6 07-25-2006 01:11 PM
2004 Monte Carlo SS RIMS F/S thebighrn Monte Carlo 0 02-15-2005 01:35 PM
1995-2004 Monte Owners manitcor Monte Carlo 0 12-12-2003 12:21 PM
