Old 02-23-2011, 08:17 AM
ericcfx1984 ericcfx1984 is offline
wow I really messed up... what heilcoil do I need for the rocker arm bolts?
I was doing the LIM install on my 2000 Olds Alero 3400 and it came time to tighten the rockers back down... I looked at the walkthru and read 124 ft/lbs... I remember thinking, wow that's a lot of pressure full aluminum... but what ever
went to tighten it down and it pulled the threads right out in a coil...
I thought, ok maybe it's just one bad one... tried it again... same result...
at this point I am thinking... "huh, something is not right..." so I checked it again... turns out the rocker arms get tightened to 124 in/lbs (plus 30 degrees), NOT 124 ft/lbs
oops...
what helicoil do I need for the rocker arm bolts?
Old 02-24-2011, 10:28 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: wow I really messed up... what heilcoil do I need for the rocker arm bolts?
Holy smokes.
About the best advice I can give is to take a rocker bolt to the parts place and they should be able to match it up.
I dont know if helicoil on a rocker arm is going to be a long term repair. You may end up pulling the head in the near future.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
How can I strip Rocker Arm bolts? rtaft Alero 3 07-19-2010 10:42 AM
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 11:45 PM
2003 grand am rocker arm bolts commerce48382 Grand AM 4 02-27-2007 07:56 PM
Broke Rocker Arm Bolt During Gasket Replacement Papi1 Trans Sport 4 11-08-2004 11:08 PM
