Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 02-22-2011, 06:36 PM
MissyS1725 MissyS1725 is offline
99 Cougar Brake and Reverse Light Problem.
I noticed on the passenger side the brake light is also Paired with the reverse light. When I press on the brake BOTH the brake light and the white reverse light will come on. I thought it was odd until I put my car in reverse and realized that the reverse light will NOT come on. Now it's only on the right side (passenger side) the other side works perfectly. Also my inside light that signal's an "external" light is out has been on. I think it has to do with this problem. I was wondering if the wiring could be wrong or if there was any way to fix it. I didn't want to put it in the shop because they tend to take "advantage" of girls. Hopefully it's something simple I can fix without spending an arm and a leg. -Thanks!
Contact via Email: [email protected]
Old 02-23-2011, 01:30 PM
inafogg inafogg is offline
Re: 99 Cougar Brake and Reverse Light Problem.
you can remove bulbs,check/clean contacts maybe replace bulbs while there
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
MissyS1725 (02-23-2011)
Old 02-23-2011, 02:30 PM
Thanks, but that didn't help I've already replaced both brake lights with no such luck. Auto Zone is saying it could be bad wiring I hope they are wrong.
Old 02-23-2011, 02:46 PM
are you able to check for voltage??do you have access to volt meter??
check for 12v, trace wiring back to where they split left/right should
be a connector.
is there a trailer hitch on car? these have been suspect on some cars
you need to look at a wire diagram, someone will chime in with wiring info
Live For Today
Yesterday is gone,
2000 cougar brake switch. HELP! MKO1988 Cougar 0 06-09-2010 09:38 PM
No thrird brake and reverse lights 70165 Taurus | Taurus Wagon 1 10-15-2008 01:57 PM
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 01:01 AM
electric problem with turn signals and reverse lights computermole LeSabre 0 09-07-2006 11:16 PM
brake and reverse lights patatoeswizard Jetta/Vento/Bora 1 07-07-2005 06:18 PM
