Old 02-22-2011, 04:30 PM
samprix samprix is offline
automatic level control
Hello to all;
I have a 1999 LeSabre and I have replaced the rear struts about 6 months ago. The auto level control was working fine. Now, the pump runs, but the shocks do not inflate. I have checked all the air lines that I can reach/see and there does not seem to be a leak anywhere. I suppose that it is possible that the pump itself is now bad. Does anyone know how to change the pump for this system or how to properly diagnose the pump prior to removal and replacement?
Thanks to all.
Old 02-22-2011, 10:03 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: automatic level control
It may be best to replace the compressor with a JY compressor assembly. It is very simple to remove the existing compressor from the undercarriage under the rear right side of the body. If you want to test the existing compressor, pull the air inflation line off of the compressor and hook it up to an air gage to test PSI capability. If it can not pump desired pressure, replace it!
Old 02-23-2011, 12:26 PM
Thank you, Sir for your response. Do you know what the operating pressure of such a compressor should be?
Old 02-24-2011, 12:03 AM
HotZ28's Avatar
AF Moderator Elite
It should pump at least 60 psi; even though the struts should not require more than 15-20 psi.
Old 02-25-2011, 05:38 PM
Good to know. Thanks very much.
Automatic Level Control Isnibs Aurora 10 09-22-2010 11:33 AM
Automatic Level Control problem? samprix LeSabre 11 07-13-2009 10:11 AM
Automatic Leveling Rear Shocks bocoogto Roadmaster 13 04-18-2006 04:01 PM
Automatic leveling 307 Yukon 1 10-31-2004 04:06 PM
95 Roadmaster Automatic Level Control akreuz Roadmaster 2 02-08-2004 12:54 PM
