air won't blow through upper vents
i have an 2006 chevy trail blazer and i can't get ac or heat throughe the upper vents only through the defrost i get air blowing
Re: air won't blow through upper vents
Hopes this helps.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr. |
Unfortunately, the Trailblazer has a completely different set of HVAC controls than the old style S-trucks which used the vacuum as described above.
Trailblazers use all electric actuators for temperature and mode controls- and they are controlled by the control head through data lines and feedback controls- and require periodic calibrations done automatically. Do you hear clicks coming from out under the dash? a sign of a broken actuator or actuator door. Does your dash temp display flash? If so, you have a HVAC code set and it needs to be read for help in diagnosis. Here is a description of your mode door system. Air Distribution The HVAC control module controls the distribution of air by the use of a defrost actuator and a mode actuator. The modes that may be selected are: Defrost Defog Panel BI-Level Floor The mode and defrost actuators are connected to the mode and defrost doors by a cam type linkage system. Depending on the position of the door, air is directed through the HVAC module and distributed through various ducts leading to the outlets in the dash. If the HVAC control module detects a fault with the mode or defrost doors the HVAC control module will try to drive the actuator for a predetermined amount of time, to defrost, which is the defaulted position for the mode and defrost door actuators. When the mode switch is placed in the defrost or defog positions the A/C is commanded on and the recirculation door is moved to the outside air position to help reduce window fogging. A/C is available in all modes and recirculation is only available in the panel and bi-level modes
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
| The Following User Says Thank You to brcidd For This Useful Post: | ||
Rick Norwood (02-22-2011)
Sorry Guys, I tried. Thanks brcidd.
