Old 02-20-2011, 05:14 PM
tmercer tmercer is offline
Question 94 jimmy signal problems
i have a 94 jimmy 4wd. i have the digital dash. the blinkers blink fast on the dash and on the lights. when i put the headlights on the left signal blinker stays on at the dash but does not blink and i cant get it to go away. also when the headlights are on on the left side on the running lights dont work .
just wonering what to do
Old 02-21-2011, 03:54 AM
old_master's Avatar
Advisor/Moderator
Re: 94 jimmy signal problems
Sounds like a bad ground or bad socket for the left front turn signal/park lamp. Remove the bulb and check resistance from the ground terminal inside the socket to chassis ground, must show less than 5 ohms. Post your results.
You have to know how it works,
to figure out why it doesn't.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 10:40 PM
1998 GMC Jimmy Directional Signal problem, makes blinking sound w/o signal on (MORE) drlabatts Jimmy 11 02-14-2006 01:21 AM
Wiper / Turn Signal Problem...HELP...'92 Jimmy... GODZZLA Jimmy 1 05-21-2004 09:27 AM
96 GMC Jimmy.....A/C and turn signal problems loyolacub68 Jimmy 0 03-27-2004 06:00 PM
