Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-20-2011, 10:07 AM
Ozarknight's Avatar
Ozarknight Ozarknight is offline
1997 GM heater hose replacement
My 1997 Grand Marquis w/150,000 mi. has a coolant leak. It appears to be at the upper heater hose connection. The darn hose runs underneath the intake manifold. Is there a trick way to snake that hose through there? or am I going to have to remove the intake manifold?
Old 02-20-2011, 11:04 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1997 GM heater hose replacement
You can leave the intake manifold on. You will have to remove the wiper cowl, however. It isn't more than a 15 minute job. Just be sure when re-installing that you connect the washer fluid lines and don't pinch it or else you'll have to do it all over again....ask me how I know :P
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
The Following User Says Thank You to Blue)(Fusion For This Useful Post:
Ozarknight (02-20-2011)
Old 02-20-2011, 12:56 PM
Ozarknight's Avatar
Thanks Blue)(Fusion - I wouldn't have thought of that. Much easier to tackle it that way
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
How do I remove heater hose? uspres2020 ZX2 1 10-03-2009 08:35 PM
Heater Hose Replacement 3mikeman Escort 4 09-01-2006 02:50 PM
Heater hose replacement george2 Taurus | Taurus Wagon 1 11-14-2004 08:29 PM
Tags
heater , hose
