Old 02-20-2011, 09:30 AM
radrodder04 radrodder04 is offline
Tdc
If I pull the head can't I find TDC just by looking at the top of the piston and when it's at the top that's TDC isn't it ? Also when putting the head back on do I have to put each piston at TDC (after I put the push rods in) and tighten the rocker arms?
I neglected to say work is being done on an inline 6 (4.0)
THANKS
for your help and advice!
Old 02-20-2011, 02:16 PM
danielsatur danielsatur is offline
Re: Tdc
Usually you want TDC, befor pulling a timing belt, or head.
1) I usually remove the spark plug on cylinder 1, and put a heavy duty paper wadding in it's place.
2)Turn the engine over very slow until the paper wad pops!
3) Your engine is now @ TDC on cylinder 1, and check all Timing marks befor removal.
@ TDC on a four stroke engine during the power stroke both intake & exhaust valves are closed, and the piston is at the top.
Hanes, Chilton, and http://www.alldata.com Auto repairs should have the torque spec's + seq.
The Following User Says Thank You to danielsatur For This Useful Post:
radrodder04 (02-20-2011)
Old 02-20-2011, 09:15 PM
Re: Tdc
By golly that was a wonderful little idea about the paper wad. Sometimes I can make things hard, I appreciate you making it easy for me. Thanks again.
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 12:02 PM
Code 8 TDC! blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 7 09-14-2003 07:17 PM
Legend TDC sensor error jayhx Legend | RL 0 07-24-2003 07:25 AM
