Old 09-13-2003, 11:26 PM
blade34609's Avatar
blade34609 blade34609 is offline
Code 8 TDC!
Hi,
I keep gettin Code 8- Top Dead Center Sensor on my ECU.
My car is a DPFI LX.
I took my car to the mechanic and all they did was reset my timing correctly. They couldnt get rid of the code which Im pretty sure is causing my 3500 RPM rev limit.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 09-14-2003, 01:44 AM
blade34609's Avatar
This is definetly a dizzy problem correct?
Do you think my distributor could be bad?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 09-14-2003, 10:15 AM
blade34609's Avatar
Re: Code 8 TDC!
yea, my dizzy must be bad because i followed the manual.
But the thing is can I use the SI dizzy temporarily just not use the b/g and b/y wires on the SI dizzy?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 09-14-2003, 10:32 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
no you cant put the si dizzy on the dx or lx motor, it wont work, the car will be expecting readings from the missing sensors, so you need to have the right dizzy for the job.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-14-2003, 04:05 PM
blade34609's Avatar
Hi,
Just read this and Im pretty sure this is my prob.
"Code 8 - Top Dead Center Sensor
It's the second sensor in the dist. It can also be located on the camshaft of DOHC engines. It determines the injection timming for each cylinder, also used to detect engine speed (rpm) to read the basic discharge duration, for different operating conditions.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up, to a 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed."
Im gonna get a new dizzy ASAP.
Anything else I should check before I get a new one?
Im pretty sure this is what is causing my misfire/backfire and 3500 RPM rev limit.
I pretty much recheked everything and this must be the prob.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 09-14-2003, 05:35 PM
crxlvr's Avatar
get a dizzy for the LX, do not buy another SI dizzy, they will not work right.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-14-2003, 06:17 PM
blade34609's Avatar
Re: Code 8 TDC!
Yeah i jus bought one from a DPFI STD car.
not bad for 30 bucks.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
code 24 zetan Corolla/Matrix/Voltz 2 04-10-2009 09:59 AM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
