Old 02-20-2011, 02:39 AM
zerocool.666's Avatar
zerocool.666 zerocool.666 is offline
the minimaster
Talking Mini cooper Top Chop 1:12
hello all,
I'm new here and this is my current project, I will put a lot of photos at once to show you how far I came.
So up to photos
it is a mini austin top chop with motor 1380, and bolt BMW K1100RS Weber carburetor 45.
it will also be equipped with a flip-front to admire the entire engine
for the appearance I was inspired in part thereof:
and for the engine that's some photos of what looks like gibberish that I put above the good engine it has kept its ramp motorcycle fuel but mine will be two instead weber
So much for the picture project, we now turn to reality!
First I cut the 4 posts and then recut the tower roof 4 as
then I fill the spaces or it is missing and I spend the same time smoothing the body
So we move on to sanding and we go there with a good heart, then traces the grooves of door and here's the result I'll spare you the details of catch amounts to putty
good that's done, now we go to the roof, I first retrieve the roof of the mini Lazareth necessarily to be 2 and cut the two roofs into 4 parts then reassemble into one because the fact to lower amounts, you could see from the photos a little higher, you have to "expand" the roof but extensively up the pictures to see how it went:
is maintained on all four sides as the mini can
and finally assembles the two parts together
the engine and now he 's not finished yet but I think being on the right track
here I'll let you see the pictures and I repost soon!
thanks for viewing and sorry for my english
Old 02-20-2011, 04:06 AM
dzsiii dzsiii is offline
Re: Mini cooper Top Chop 1:12
good idea! waiting more progress!
Old 02-20-2011, 09:17 AM
endac's Avatar
endac endac is offline
Looks really cool, nice work so far
Old 04-03-2011, 03:25 AM
the minimaster
Arrow Re: Mini cooper Top Chop 1:12
hello,
so I'll just show you the inside and the little touch up the engine but I'll explain it in pictures
http://www.specialist-components.co....dCategoryID=36
So here are some pictures of the little editing:
before
after
there's just the top right of the head as I sanded the 16 valves because her form was the form of 8-valve, so much for the explanation
a little less light and more details on WEBER 45
and yes it is a breech BMW
and up to the hoop as the true
but first to the hoop that is taken
more it is heated and a little
to give it I do not know yet if I will add bars or not
and it takes both parties to assemble
then are assembled to see if it works well
and adds body
then cover
and it goes!
gone is gone for good "alcantara" placed on all seats
so here following the laying of tack with "leather"
back seat
then a seat, I do not put the other is the same as
and then gluing the leather on the upper
Front Seats
and the back seat
and
and the end for the full leather
then drilled 2 small holes in each piece
I glue two small rods into the holes in the headrest but I'm not stuck on the side of the seat to make it functional as a true
and assembled
and that's a nice leather that I can sell it more expensive
hoping you like it
Old 04-03-2011, 05:49 PM
kaho's Avatar
kaho kaho is offline
Awesome work on the leather! Must have been a long time to trim them all perfect! Will you add the strips at the edges where the pieces join?
Old 04-03-2011, 07:22 PM
da_ashman's Avatar
Awesome work so far!! Looks like its gonna be an amazing project!
Old 04-04-2011, 02:25 AM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
The leather material work is amazing, how long did it take you?
or
Old 04-04-2011, 03:50 PM
the minimaster
thank you very much for the compliments and yes I'll try to put a red thread on as true and it took me about 3.5 hours to count them without the drying time for glue
Old 04-11-2011, 08:53 PM
Jocache83 Jocache83 is offline
looking good man and im loving the seats! keep it up
Old 04-12-2011, 03:30 AM
wolvyreen's Avatar
wolvyreen wolvyreen is offline
Nice job!
Old 04-22-2011, 04:22 AM
the minimaster
thank you and hello to all,
then these are small steps
a little inside:
and turn the roof now
it delineates
and cold cuts are
and is sanded a bit to make it clean
at first I had to cut the wheel because they were too far from reality so we could see inside the car when I opened the flip-front so as usual we scratch
but then again the wheel is stuck on deck
then we go to serious stuff
not bad at first saw no? and that is why I had to decline
then eventually clog it up reinforcements
and adjusted, not yet finished but I prefer the glue is dry to handle it well
and small steps with the carpet but I am the most annoying, now it will be almost as squares
good, the carpet, it's done
then we go to the dashboard Me
First I put a rod "guide"
then I make the bottom panel
more photos here
and a small forward at the carburettors
and here it was easier than I thought and it will have it's still more realistic right?
and this is the moment your comments
Save a tree, eat a beaver
Old 04-30-2011, 09:01 AM
the minimaster
hello all,
Here are some small steps:
a small tachometer with shift-light
then I will do so has also redo the deck of the engine
I made the small bracket that holds the clutch like this one
and mine
Then I decided to do my flip-front in another way
So I glued the cover on the wings into a single piece
and a small photo of the car without his flip-front
then again and again for news and still scratch, so I first made ​​the ignition coil
Then I attacked the throttle carburetors
and here is what position he will
well it still lacks the cables, then I'll just refine the rooms upstairs and down, but it must go through the first paint box
and the small tab located on the axis
and to clean
then the steering wheel before and after but it still lacks the small screws
there he will tank, electric pump and something else
originally
and once rebuilt, and yes I can not get enough to rebuild all parts
then to turn the filter
and it is left for the pictures!
First, the front subframe which I remade the front crossmember as true
then it was the turn of the exhaust manifold that I am finally in a tube of 4mm which I have "appointed" the end so that it fits (and no ulterior motive)
and for those who want to see what it looks like in real life:
http://www.theminiforum.co.uk/forums...&hl=K1100&st=0
Old 07-25-2011, 02:05 AM
the minimaster
hi all,
a big update after a long absence
first of all, the engine received its final color:
then I put some small "bolt"
:s crewy:
and the weber
and I decided to make a panoramic glass roof
the blue plate is transparent styrene I thermoformed in hot water
then I took care of fixing the trunk door
and I glued the wings
the subframe received his personal touch and support damper directly above
and finally the painting of the body!
without the flash we see the true color better
and outside, there's more to pass the clearcoat
So much for the time being, comments are welcome
Old 07-25-2011, 06:50 AM
Wishieftrottle's Avatar
Wishieftrottle Wishieftrottle is offline
Very nice color!!!
But I feel you could color engine more precisely....
Anyway I will have eyes on your thread :-P
Old 07-25-2011, 08:06 AM
luchoteam's Avatar
luchoteam luchoteam is offline
Great job!!!
I love the color....what color is that?
John Cooper Works' Mini Cooper S druid_99 Completed Projects / Gallery 13 01-25-2011 02:40 PM
Official Photos of New 2007 MINI Cooper and Cooper S Ignite Mini 1 | Cooper | Countryman 0 08-14-2006 02:12 PM
2nd Chop-Mini Cooper Evo Edition Imports615 Graphic Manipulation 5 12-01-2004 07:15 PM
Mini Cooper Chop *WARNING: Kinda Ricey* Blowncivic1320 Graphic Manipulation 10 11-19-2003 12:17 AM
Chopped Mini Cooper S white2abbit Graphic Manipulation 7 10-31-2003 10:34 AM
