Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 02-18-2011, 06:54 PM
UseDaGreyMatter UseDaGreyMatter is offline
Where is the OBD1 located at?
I just bought this 1982 ford E series Econoline van. 5.0L V8 2BBL , automatic, PS . She runs great but is in need of a major tuneup. Mileage is in the toilet. There are two major questions,.
Question 1, I looked online and it looks like this van has OBD1. Where is the hook up to attach a code reader or key to? We have looked every where under the dash and do not see it.
question 2. Have isolated the brake light, back up light, parking light etc problem to the hazard switch in the steering column,. this is not a cheap part, is there any other thing it could be before we tear into that?
Thanks
Old 02-25-2011, 01:00 PM
inafogg inafogg is offline
Re: Where is the OBD1 located at?
there may not be a connector,on the older fords 83,84 - mid 90's they have
a wire connector (2) L/side of engine in rear, 6 pin & 1 pin.use a wire to jump connectors
then you can read the flash codes
w/key off jump connectors,then turn key to on/engine off,the ses lamp
will flash codes
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 02-25-2011, 01:36 PM
HERES A PICTURE USING A JUMPER WIRE OR TEST LIGHT
OBD1 Codes Retrieval (Pre-1995 Cars and Trucks)
Ford 1985-95 OBD1 code self-retrieval
When checking engine service light on Ford vehicles made before 1995, you can get the code yourself using a $5 tool called "test light". All you need is to hook it up to the vehicle’s diagnostic connector and turn your key on and watch the codes being flashed in your dash panel.
Shown here on your left how the FORD OBD1 diagnostic connector is set up.
Live For Today
Yesterday is gone,
Where the AK people at? TheNotoriousMogg Alaska and Hawaii 6 01-13-2009 10:09 PM
Wheres the EGR located? Albanianmafie Corolla/Matrix/Voltz 1 10-23-2008 06:52 AM
Where is the AMP located at? HondaSi88 Villager 2 02-05-2005 09:23 PM
Where is the PCV located at on a 01 DOHC? chasmanz28 Taurus | Taurus Wagon 1 10-19-2004 12:39 PM
where is trailer towing harness located at front of truck on 1998 chev c-3500? modracer C/K 1 01-07-2004 05:44 PM
Tags
1982 , e-series , econoline , ford , obd1
