Old 02-18-2011, 07:22 AM
Koudy's Avatar
Koudy Koudy is offline
Subaru WRX Twins
Hello,
I built this two kits as a tribute to SWRT and to Colin McRae who reached world title in 1995. I used tarmac transkit with decals from Renaissance and Zero paints.
Enjoy!
Old 02-18-2011, 09:45 AM
backyardinc's Avatar
backyardinc backyardinc is offline
Re: Subaru WRX Twins
nice set of wrx's!!!!!!!!!!!!!
..SIMPLICITY KILLZ..
FACEBOOK :: BACKYARDINC KUSTOMZ
Old 02-18-2011, 12:47 PM
702VegasLife's Avatar
702VegasLife 702VegasLife is offline
Ahh my favorite car ! Nice work !
Old 02-18-2011, 03:31 PM
stevenoble's Avatar
Two very nice Subaru's. Which Zero paint did you use..?? It looks the perfect shade..
Steve Noble
Old 02-18-2011, 05:43 PM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
I always liked these older Subaru Rally Cars, excellent work!
or
Old 02-19-2011, 04:18 AM
Koudy's Avatar
Hello all, thanks for your comments.
Steve: I used 555 Rally Montecarlo Blue ('94-'96) 53C. First I had white surfacer on body but shade looked too pale to me. So I put gray surfacer first and than I reached the right shade... I think :-)
Old 02-19-2011, 04:37 AM
endac's Avatar
endac endac is offline
Beautiful pair, both look fantastic
Old 02-19-2011, 05:40 AM
stevenoble's Avatar
Thanks for the reply about the paint, most appreciated. Can I also ask you how easy was the tarmac transkit to use..?? Any fit issues or things to look out for..?? Reason I ask is because I was thinking of buying one myself to convert one of my Subaru's to tarmac spec. I also noticed they produce one for the Subaru Legacy as well...
Steve Noble
Old 02-19-2011, 07:52 AM
Koudy's Avatar
Steve: Transkit is OK, no problem with it. You´ll need to modify few things. First you need to bend down rear arms to fit them with rear suspensions which are shorter in tarmac version. Than you should cut out, flip and than attach again rear axles to make them fits with hubs.
Quite hard is to bend down front arms, so you should better drill holes at the bottom of resin suspensions and make them longer with hard wire which you will glue into the holes. I used part of needle instead of wire. That´s all, no more modifications.
Legacy kit has the same chassis, so the changes will be the same I hope. I´ll built all three Colin´s versions of Legacy, but all in gravel specifications (RAC, 1000 lakes and New Zealand).
I thing TK for Legacy is the same except rims.
I hope this will helps you, I can make photo of tarmac chassis, if you want to.
The New Subaru Canada WRX STI Spot subarucanada General Discussion 1 07-13-2012 01:44 AM
Subaru Impreza WRX STi S204 edition (Completed) modelaholics Completed Projects / Gallery 15 08-05-2011 08:10 AM
FS/ WRX Powered Justy on Ebay Theon315 Cars/Parts for Sale/Exchange 0 05-06-2010 10:42 AM
Subaru Impreza WRX STi S204 edition modelaholics WIP - Street 20 07-05-2009 05:49 AM
Kei car lovers - Subaru REX twin drift! JeffForSale! Drifting 7 10-28-2003 04:52 PM
