Old 02-17-2011, 07:12 PM
someday31 someday31 is offline
Towing with a 1500
I am going to be towing a minivan, Toyota sienna on a uhaul trailer, all 4 wheels will be on the trailer. I will be towing about 200miles roundtrip, about 4hrs total. I have a 1500 5.3 2003 silverado....what should I tow in.... 2wd, auto??? Drive or overdrive? Should I use that tow haul mode button on the wiper arm? Any tips for not wearing on my truck too much?
Old 02-17-2011, 07:35 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Towing with a 1500
Generally i try to stay in 3rd with the tow/haul on. I towed a verneer (sp?) chipper on the hitch, a john deere 110 with attachments and a dirtbike in the bed with my 01 with surprisingly little effort. Just be sure to keep distances and if it is hilly terrian you will prob need a trailer with brakes. There are people who tow on a regular basis on here so just wait until they chime in.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-17-2011, 07:52 PM
j cAT j cAT is offline
I have a 4000lb boat with surge brakes . when towing that load , the braking is no problem . the pulling is in tow mode, 3rd gear and speed is kept below 70MPH. 65 MPH is what I do. gradually increase and decrease speed.
I have loaded the bed with a good amount of weight around 1200lbs or so. this is when the braking is an issue. the heavier load with just the vehicle brakes you must keep a longer distance , and also brake with caution , so as to not over heat the brakes. so prepare ahead of time when slowing down is to occur.
only 2wd ...any 4wd is for wet /snow pavement or off road no pavement.this vehicle has only part time 4wd in any 4wd position.
when towing make sure the engine oil is at the full mark. recheck oil when refilling the fuel tank. oil consumption can increase when towing long distances. make sure the tires , ALL have the correct pressures.low tire pressures will cost you on fuel. I use 89 octane when towing the boat. this should reduce the possibility of knock code from coming on.
I always run with 87 octane with normal use.
you should be good towing with that amount of load, just take your time.
How is towing with 2004 1500? Rodie40 Ram Pickup | Ram SRT10 1 08-15-2007 08:50 PM
Towing with my 99 1500 geebeer Silverado 7 03-21-2007 02:54 PM
Towing with a Suburban 1500 gmonk C/K 3 06-16-2004 09:01 AM
What do you tow with your Cherokee ? CoolBlue87GT Cherokee 6 02-07-2003 05:25 PM
towing with pathfinder Steel Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 07-29-2002 09:52 AM
