Go Back   Automotive Forums Car Chat > Hyundai > Tucson
Old 02-17-2011, 08:23 AM
drdrew33 drdrew33 is offline
05 Tucson won't start after its warm
Just bought an 05 Tucson, V6, 77000 miles. It'll start fine when cold, but after I've driven if for a while and stop then come back out to it, say 10 minutes later, it takes 3 tries to start the motor. Any ideas what's causing this? It had a new fuel pump put in about 2 months ago. I was thinking spark plugs but everything I've read says the iridium plugs should last a lifetime.
Old 03-02-2011, 11:08 AM
UPDATE: 05 Tucson won't start after its warm
After having my mechanic diagnose the problem, it turns out it was the Fuel Pressure Regulator, the diaphragm inside was shot. I had it replaced and no problems starting since. I've read that the fuel system in the 05 Tucson is a problem. Mine has a new fuel pump installed in January, and now a the pressure regulator, hopefully this remedies all fuel problems.
The Following User Says Thank You to drdrew33 For This Useful Post:
danielsatur (03-02-2011)
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
87 F150 - won't start after warmed, changed ECT sensor - same code 21 rosenbarn F Series 3 03-21-2008 06:12 PM
F250 won't start after warmed up ru469 F Series 7 05-08-2007 08:56 PM
Problem with car starting after its warm up deb789 Grand AM 0 12-10-2005 04:44 AM
98 2500ram won't start after it warms up blbigham Ram Pickup | Ram SRT10 0 07-15-2004 07:07 PM
