Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-31-2005, 05:52 PM
ru469 ru469 is offline
F250 won't start after warmed up
1990 F250 4x4 with 460, starts up fine, but after it has warmed up, it won't start anymore, if it hasn't warmed up , i can start it and turn it off and start it over and over again with no problem, thanks for any help
Old 08-07-2005, 10:44 AM
Robin Hood Robin Hood is offline
Re: F250 won't start after warmed up
My F-150 had this problem. I found the coil was bad.
Old 08-10-2005, 01:41 AM
Kitt Kitt is offline
Smile Hard to start...when warm/hot
Just wanted to let you know that I too am looking for a fix for this..quite irritating when I have impatient horses in the trailer at the gas station and it won't start till it is 'cool' enough! My motivation that had me look for and join this interesting forum.
Old 08-16-2005, 11:49 PM
ihatemyford ihatemyford is offline
i have the same issue i have replaced the ignition module, the and the coil. but i still can't find the problem.. you arnt the only one!
Old 08-22-2005, 01:55 AM
pooze pooze is offline
I've read all over the net this is because of a bad CTS (coolant temperature sensor). Careful though there's two of them, one that is used for your gauges and one that the computer uses. The one for the gauges has a single wire on it, the other one has multiple I believe. Not sure where they are on a 460, but facing the motor looking in the engine compartment on a 302 the CTS is on the passenger side. Make sure you teflon tape the threads on the new one when you put it in so it doesn't leak.
Old 12-07-2005, 01:08 PM
david25 david25 is offline
Question 1996 F250 mess
my F250 shuts off while going down the road I have done a complet tune up, replaced compuer, and coil. Still have same situation, PLEASE HELP...
Old 05-08-2007, 08:41 PM
chargerpaul chargerpaul is offline
To ru69....Sounds like a "heat soak" condition to me--when your truck is cool and you start it, the starter spins ok but when the truck is hot, the heat transfers in to the starter and swells the armature just enough to bind it up and the starter won't turn. Solution is to fabricate and install a heat shield over the starter between it and the block and exhaust system or wrap the starter in "header tape" which is a heat resistant tape used on headers...can be bought at most parts stores or performance shops. Quick fix is to pour cool water on the starter housing but not too much...use a funnel and hose to get past any restrictions. Good luck, Paul
Old 05-08-2007, 08:56 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Old thread.
if it's more than 3 months old, it's dead and shoudn't be brought back.
i'm not here to be a pain in the ass, it's just the rules. PM me if you feel the need to.
Seatbelts Saved My Life
Closed Thread
