Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-16-2011, 09:57 PM
mnrogers59 mnrogers59 is offline
Jeep hard to start....
I have a 2000 Jeep Wrangler Sport (TJ) which I am having problems with starting. I have the 4,0L 6 cyl. engine and when I try to start it the engine turns over fine but it turns over for quite awhile before it finally does start. After I get it started it runs just fine. It's just starting it that takes awhile. I have run fuel injector through it but it still acts the same. I am wondering if it could be the fuel pump or some other issue....
Old 02-21-2011, 07:11 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Jeep hard to start....
There are a few things on the 00 model I'd check:
1) How long since your spark plugs were replaced?
2) When you start, try turning it to "on" for a few seconds and let the fuel pump charge the system. I know it's not supposed to lose pressure, but more than one of the 4.0's I've had start right up when you let the fuel pump run for a second.
3) How many miles? I ask because the Crankshaft Position Sensor could be causing the hard start; this begins after maybe 90k or sometimes more.
4) What transmission?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-25-2011, 12:06 PM
I did replace the plugs not too long ago. I will try the thing with the key....does that mean the fuel pump could be bad???? I have about 110,000 miles on the vehicle and how do I determine if it IS the "Crankshaft Position Sensor?" I really appreciate your helping me....
Old 02-27-2011, 06:35 PM
You're welcome.
Turning the key to the "on" position for a couple of seconds doesn't mean the pump is bad, it just means that the engine needs more fuel available at start.
The CPS, if it's bad, will cause your engine to shut off when it's running, and can cause hard starts, engine stumbling/misfire, and if it's an automatic, odd shifts.
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 06:14 PM
1996 Jeep Cherokee won't start JSValentine Cherokee 1 02-03-2011 03:51 AM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 02:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 05:21 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 09:52 PM
