Old 02-16-2011, 01:20 PM
huey224 huey224 is offline
sliding door problems
I have a 03 windstar se with dual power doors the owner i got it from said he got hit in a parking lot and replaced the door. u can tell cause the glass isnt tinted its clear and the speaker wont work or the power assist. I took the door panel off and everything was in there and hooked up. finally i looked at those little round things that contact that metal pad on the pillar when its closed. my passenger side has 7 fingers and 7 little plates. the driver sliding door (the one that was replaced) has 5 fingers and the pillar has 7 just like the other side. what exactly are they for? i push the door switch for the replaced door and you can hear the motor click but nothing else. passenger side works excellent. are they just for the speaker? when its closed it shows the door as closed?
Old 02-16-2011, 09:25 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: sliding door problems
The 5 pin version indicates the door came form a van without the power sliding door option, needless to say the 7 pin version is the PSD capable version. I've uploaded the connector pinouts of each version in case you are interested, maybe there is some way to replace the metal piece with the pins or you can figure something out of it.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-16-2011, 10:37 PM
well i was wandering if i could replace all the stuff out of a psd door into this one the only difference i seen between the two were the psd has the door popper that opens the door not pulls it. cause the motor is in the back right? cause i took my passenger side the one that works panel off and everything looked the same just no door popper and when you push the button for the door u can hear the motor click in the back but the door wont pull or close i figured they might have unhooked it when they changed the doors.
Old 02-16-2011, 10:45 PM
olopezm's Avatar
That's possible if they didn't install the cable and instead they left the rollers then the door won't work, you might try and look for a psd and see if these parts are interchangeable or you'll need the whole thing.
Old 02-16-2011, 11:15 PM
I garuntee they hooked the cable back up cause that thing is hard to pull just like the other door when you have the psd off. i figured maybe it would close if it was open but no deal just clicks so tomorrow im gonna take it apart and dig a little further. my door lock dont even work on it im thinking i can just find a psd door like i was saying and put it all in it
Old 02-16-2011, 11:18 PM
grog11 grog11 is offline
The power door initialization process when you install your 7 pin module replacement.
Power Sliding Door Initialization
1. Disconnecting the battery or CJB fuse 6 (15A) will cause the power sliding door control module to lose memory. The power sliding door initialization procedure must be carried out before the power sliding doors will operate under all conditions. The power sliding door initialization procedure is a learning process for the module to identify the full open position and the full close position. After power is restored to the vehicle, initialize the sliding doors as follows:
1 Make sure both power sliding doors are fully closed and latched.
2 Make sure both power sliding doors are unlocked.
3 Make sure the vehicle is in PARK.
4 Make sure that the fuel filler door is closed.
5 Switch the overhead console power sliding door On/Off switch to On.
6 Note:
The keyless entry transmitter or B-pillar switches may be used in place of the overhead console Open/Close switches to initialize the power sliding doors.
Press the driver and passenger overhead console Open/Close switches to open the driver and passenger power sliding doors.
7 Note:
After the power sliding doors are full open and stopped, press the driver and passenger overhead console Open/Close switches to close the driver and passenger power sliding doors.
______________________________________________
Photo of the top white inside door motor and cable sheath that wraps to the outside and the PSD
Old 02-16-2011, 11:30 PM
sweet thanks ive tried the whole resetting thing but it still clicks so i dont know what theyve done yet till i take it apart. but thanks for all the info especially the pic i can study it tonight that way i know whats ahead
Where is located the sliding door AJAR switch? serge_saati Windstar 2 10-06-2009 06:31 PM
Passenger door and Sliding door problem?? lionelkirk2004 Caravan | Voyager 2 05-19-2006 02:52 PM
Passenger door and Sliding door problem?? lionelkirk2004 Caravan | Voyager 0 05-14-2006 09:00 PM
sliding door problems illestaccord Odyssey 1 12-30-2003 02:35 AM
