Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-15-2011, 06:45 PM
zamengof zamengof is offline
battery replacement for 07 camry
today my 07 Camry original battery died, so it lasted 4 years and 6 months
I bought another battery at Costco right away, however Costco battery is smaller
now when I am staying on a red light I feel vibrations, probably because new battery is not that tight
what should I do?
Old 02-15-2011, 09:03 PM
danielsatur danielsatur is offline
Re: battery replacement for 07 camry
Stop at a local auto parts store, and buy a wrench.
They probably will loan you one.
Old 02-16-2011, 12:59 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
When fitting a battery, standardized battery application numbers are used to verify what battery group size (labeled on your battery) is the right one for your car. Your group size should be either 24F or 35 depending on your engine size according to this chart. Determine which engine you have and check this chart to see if they installed the correct battery: http://www.toyota.com/pub-share/pdf/...y10-11_fin.pdf If it's wrong have Costco correct their error.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-17-2011, 12:25 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
From the chart RIP provided it looks like your car can use the 24F, or as an option the 35. In my area Costco does not install the battery for you; they only sell them. If you are going to try to retighten everything yourself, you will need a 10MM wrench. If you have to remove the battery cables for any reason, remove the negative cable first and reinstall it last.
Also, if the battery provided is not tall enough go back to Costco and see of the offer a free adapter for your battery and car combination. It's just an extra spacer that goes on top of the battery. What I have done in the past if a battery is just a bit too short is to get some 1/2 vacuum tubing or even an old worn out garden hose and cut about two 3-4 inch length segments and then slit them open all the way lenghtwise with an exacto knife or a sharp scissors. Then remove the hold down and put the 2 cut pieces under where the hold down contacts the battery. Then retighten the hold down. This can be done without removing the battery cables. Just be certain not to touch the 2 battery teminals/posts together with anything metal. This is really pretty easy to do.
Mike
Old 02-17-2011, 01:08 PM
somick's Avatar
somick somick is offline
Your Camry needs to learn your driving pattern. Keep driving and you will see improvements (of course if your battery is the right size).
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 12-03-2013, 09:55 AM
wolv23 wolv23 is offline
Maybe this will help: How to Replace a Toyota Camry Battery
It shows you how to replace the engine battery in a Toyota Camry
Hope it helps some other people passing through...
Toyota Prius Battery Replacement isearch100 Prius 2 07-11-2013 02:53 AM
2005 Solara Battery Replacement Tips... Intuit Solara 3 04-15-2010 08:05 PM
Door,trunk and ignition lock replacement for 1990 Camry. JOET/CAMRY Camry/Camry Hybrid/Vista 9 03-24-2006 07:11 AM
Battery replacement for Diablo ChristAlmighty Diablo 4 02-23-2003 11:59 PM
