Old 02-15-2011, 06:47 PM
amanaman1 amanaman1 is offline
Chrysler TPS Readings
Is it normal for a Chrysler TPS to read around 14-15% when throttle closed and only around 75% WOT (engine off and key on)? My scan tool shows all three of my 98 Grand Caravan, 2001 Neon, and 2003 T&C with the same readings as indicated. Vehicles run fine. Reason I ask is I also have a 97 Chevy Lumina that reads 0% closed and 100% WOT. Is this just a chrysler thing? Wanted some advice as it seems unlikely I've got three bad sensors on three different Chrysler vehicles all giving me the exact same bad readings. Thanks
Old 02-15-2011, 11:40 PM
jpb53 jpb53 is offline
Re: Chrysler TPS Readings
Yes normal. Chrysler' are mostly a speed density system; no MAF ( mass air flow sensor). Your Lumina has a MAF which gives an input of the airflow into the engine. 2 completely different systems. Each work as they are designed and you don't have codes for TPS votage high so don't worry about it. System working as designed.
The Following User Says Thank You to jpb53 For This Useful Post:
amanaman1 (02-16-2011)
Old 02-16-2011, 07:05 PM
Ok. I appreciate the response and thanks for the detailed explanation.
EveryOne with Transmission problems... A Chrysler Secret...! Read This...! GeorgeArthur3 Caravan | Voyager 96 05-19-2021 07:35 AM
Impossible TPS problem entrepa Sidekick 0 10-25-2010 08:25 PM
87 Chrysler Fifth Avenue Vinyl Top samuel_colwell General Discussion 1 10-06-2010 12:28 AM
Testing my TPS jmunny Durango 1 12-22-2009 11:57 PM
93 Chrysler Imperial with a different but broken Master Cylinder ERPM General Discussion 0 08-04-2009 10:07 AM
