Old 02-15-2011, 04:47 AM
[email protected] Russell@ecewb.com is offline
95 escort Gt won't start
I have a 95 ford escort GT 1.8 dohc and I have no power to my fuel pump but I have spark and every thing else works any ideas I could use the help thanks
Old 02-15-2011, 02:16 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 95 escort Gt won't start
How did you determine there is no power?
When you turn the key from off to on you should hear the fuel pump build pressure.
If you hear it building pressure then the problem might be with the inertia switch in the trunk.
If you are certain there is no power then your first job is to check fuses. If fuses check out alright then you either have a bad pump or a short in the wire somewhere... it will take a little troubleshooting but should not be too hard to narrow down.
Old 02-15-2011, 05:07 PM
Well we have power and a new pump but when you turn the key to the on position it dosent turn on
Old 02-16-2011, 10:27 AM
If you are certain that you have power and a working pump then your problem is most likely going to be in the ignition switch.
You will have to troubleshoot the circuit to be certain... but if you are savvy enough to do it, you can disconnect the wiring from the ignition and use some jumpers to figure out if the switch is your problem.
Also make certain that your inertia switch in the trunk has not been tripped.
Old 02-24-2011, 09:50 AM
Intuit Intuit is offline
Fuel pump relay may differ between years in it's location, but on the '94s it's on the passenger side firewall in the engine bay. The other relay next to it is the AC/clutch relay.
2003 ZX2 won't start uspres2020 Escort 14 01-31-2010 12:01 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
'97 Escort-won't start-not battery-won't turn over HelpSingleFemale Escort 3 12-02-2005 04:58 PM
92 Escort won't start but will push start robyn144 Escort 4 07-21-2004 08:19 AM
93 Escort won't start greykey Escort 2 09-16-2002 07:03 PM
