Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-14-2011, 06:29 PM
donidavis donidavis is offline
96 Eclipse Rs 2.0 Non-turbo
Im having a problem with my car back firiring. It idles fine a 2000 rpm but at 1000 it just act funny like it wants to cut off! Now my engine light came on and its throwint a code... the coad is 1294. can some one help me! i got a new battery and it keeps going dead... then i found out that my alt was bad so i took the engine out changed the alt all belts even the timing... and its still doing the same thing. When i try to accerlerate it stutters and jumps really bad then eventually cut off... oh and i chaneg eht fuel pump and the fuel filter! Can anyone help me?
Old 02-15-2011, 08:52 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 96 Eclipse Rs 2.0 Non-turbo
You pulled out the engine to replace the alternator and the timing belt? Im not really sure on the work you did? Did you change the timing belt? Did the car run fine before you did this work? Maybe the timing is off a tooth
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-16-2011, 06:26 PM
Na, i didnt touch the timing we just checked and made sure that it wasnt off at all! i just put a serp and alt belt on! I took the engine out of a automatic 96 eclipse and just put my tranny on it. thats all i did and idk whats causing this backfire. do you think the EGR valve would cause this? I was also looking at my car and i dont have a EGR silonoid...
Old 02-17-2011, 10:26 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
EGR won't make a difference like that. I've had defective, broken, and EGR deletes on numerous cars and never had problems with backfiring. It recycles the exhaust gas back into the intake. Wouldn't cause a problem like that if it wasn't working or whatever.
Originally Posted by P1294
Target Idle Speed Not Reached
  • Mechanical condition vacuum leak
  • throttle cable not free
  • idle speed screw misadjusted
I would pull off the whole TB and check it out with carb cleaner. Pull the IAC and TPS, clean the IAC and it's passages, including the emission ports on it and then check botht he IAC and TPS for proper resistance. Then check all vacuum lines.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2011, 08:33 PM
Ok... now me and some friends were standing outside and we just let it run for about 30 mins and then the car caught on fire and the ground did too! so if my converer is clogged up or messed up will than make my car backfire?
96 Eclipse RS 2.0 non turbo Timing donidavis Engine, Transmission and Drivetrain 1 01-17-2011 02:36 PM
96 Eclipse rs 2.0 non turbo Check Engine light donidavis Eclipse Problem Diagnosis 6 12-02-2010 09:39 AM
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 09:23 AM
