Go Back   Automotive Forums Car Chat > Ford > Freestar
Old 02-14-2011, 11:01 AM
focus1 focus1 is offline
2006 freestar squeel
Does anyone else have this problem 06 a [COLOR=blue! important][COLOR=blue! important]freestar[/color][/color] when i drive 40 km or faster i get very annoying squeel from the front [COLOR=blue! important][COLOR=blue! important]drivers [COLOR=blue! important]side[/color][/color][/color] it goes away if you make a right turn it does not change with braking i think it might be the bearing but does not have the symptoms grinding , low hum of a faulty bearing i have checked the front end the [COLOR=blue! important][COLOR=blue! important]brakes[/color][/color] i have replaced front brake pads i notice the front rotors on the indside have a little bit of rust build up i dont know if that would cause noise i just dont know what else to do any help would be greatly appercated
Old 04-19-2011, 07:26 PM
rwb22's Avatar
rwb22 rwb22 is offline
Send a message via AIM to rwb22
Re: 2006 freestar squeel
Did you ever solve the problem? We have two 06's at work doing the same thing. Dealer has taken the entire front end apart, check bearing, brakes and everything else. Problem is still not solved!
Thanks!
94 Jimmy SLE 4x4 4.3 L Vortec
Old 04-19-2011, 08:37 PM
Yes I finally got it figured out I replaced the wheel bearing assembly
YAMAHA YZR-M1 2006 CAMEL No.46 YongGun Park Completed Projects / Gallery 31 10-07-2012 02:32 AM
supercharging my 2006 Eclipse kmcclain123 Eclipse 2000+ 5 04-14-2011 10:54 AM
2006 gmc sierra hd 7 pole trailer plug peanpone@hotmail Sierra 0 05-02-2009 09:50 AM
Change 2006 Allure Headlight kale39 LaCrosse/Allure 1 04-28-2009 06:05 AM
Any Freestar impressions? Bigg Russ General Discussion 3 02-13-2006 06:37 PM
