Old 02-14-2011, 06:57 AM
ColoradoSilverado ColoradoSilverado is offline
Heater problem
Heater itself works fine but I can't get (warm) air to blow by my feet, the other settings work just fine but when I turn the dial to my feet there's a very minmal amount of warm air. Is there something that is blocked maybe?
Thanks,
Bert
My Truck:
2000 Silverado,, Z71
5.3 Ext. Cab, Long Bed
Original motor + transmission!
As of 3/21/14, I'm at 266,300+ miles!
My wife's Truck:
2005 F150 Lariat CrewCab
(Way nicer them my truck!)
Old 02-14-2011, 09:21 AM
j cAT j cAT is offline
Re: Heater problem
take the filters out and see if it blows better. If no filters in the air box you could have a mess of debris in there blocking the heatercore/evap unit. many have had this occur.
Old 02-14-2011, 06:20 PM
Re: Heater problem
Where and what do I take apart? Is there a part under the dash that comes off?
Thanks,
Bert
My Truck:
My wife's Truck:
Old 02-14-2011, 07:18 PM
Re: Heater problem
Thanks,
Bert
under the glove box is this plastic cover , remove. in the right corner is the connections to blower/blower motor.to the left a few inches is the 1 inch wide 6 inches high plastic cover for the air filters. remove the screws and pull out the 2 filters.If / since you have no knowledge of all this it must be really messed up with crap..
Old 02-15-2011, 08:42 PM
Re: Heater problem
Turns out the filter was clogged up pretty bad. Now it blows a 100% better (without the filter), wouldn't this affect all the vents? It was blowing just fine at the windshield, and the dash vents.
Bert
My Truck:
My wife's Truck:
Old 02-15-2011, 08:44 PM
Re: Heater problem
Bert
be sure to install 2 new filters. you don't then the dash will require removal to remove all the debris that will damage your HVAC controls and cooling coils........
Old 02-16-2011, 11:40 PM
Re: Heater problem
j cAT, you say 2 filters? There was only 1 in there and if I look at Napa parts online it say's quantity 1 per vehicle?
Bert
My Truck:
My wife's Truck:
Old 02-17-2011, 07:33 AM
slo99sierra slo99sierra is offline
Re: Heater problem
Bert
There are 2, the you pulled out can be clearly seen, I believe the other one is recessed either up or to the side (forward of the truck)
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work.
Old 02-17-2011, 08:40 AM
Re: Heater problem
Bert
the filter must be 2 pieces or it will not fit. one piece would be toooo big to slide into the slot. they set in there side by side.
the box the new filters come in have 2 separate filters. if not then its the wrong filter.
Old 02-17-2011, 07:34 PM
Re: Heater problem
Also sounds like the parts store guys don't know what they are doing either.
Here's an idea: take both old filters with you when you go back to get the new ones.
98 Park Ave Heater Problem! Firemanemt1970 Park Avenue 5 12-05-2010 03:02 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 05:24 PM
Heater problems/A/C problems Dan521 Crown Victoria 2 02-07-2006 08:04 AM
86 325e heater problem maxmuscle 3 Series 1 01-30-2002 06:10 PM
