Old 02-13-2011, 05:36 PM
tebo77 tebo77 is offline
94 Caravan AWD Not Engaging
Our 94 Grand Caravan AWD is not engaging when the front wheels slip. It also makes a whining noise while backing up, don't know if that's related. What could cause this? PTU? Greatly appreciate any help!
Old 02-26-2011, 06:27 AM
mikefaster mikefaster is offline
Re: 94 Caravan AWD Not Engaging
The PTU (which is the transfer case) has a ring and pinion and it is a direct drive type of unit...
There is a sprag on the driveshaft that DOES NOT allow to rear wheels to spin WITH the front wheels when going in REVERSE... The drives shaft just freewheels in reverse... Because of the crude method, Chrysler had to do that or else people would be breaking things and wear out tires all the time...
Whining at idle or when driving? Sounds like a tranny pump whine... So you may need a transmission soon... They sell bearing kits for the PTU because once you break on of the gears, they are not orderable... Changing the bearings will prolong it's life for sure... Then use full synethic gear lube for lubrication...
Cost: VERY friggin' expensive...
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 04:58 PM
AWD does not engage Sonwatcher Bravada 16 06-05-2009 08:58 AM
2000 caravan trans not engaging munchrow Caravan | Voyager 10 12-08-2008 12:32 PM
1991 Caravan AWD will not move 8950LX Caravan | Voyager 0 05-15-2008 11:00 AM
2003 AWD Montana During Startup Idle will not engage 1spoonman Montana/Montana SV6 2 01-12-2006 06:33 AM
