Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-12-2011, 09:50 PM
consultIII consultIII is offline
AOD slipping in 4th
my 1988 crown victoria lx with 5.0L and AOD trans.
Yesterday, detected engine flare in 4th on acceleration. No slipping in m1 , m2, m3 or R. Completes all shifts normally. Trans fluid is in great condition and at proper level.
Want to air check the overdrive band servo...Can I do it without the special test plate tool? If I can't; was going to change it out the servo.
Is there anything else I should check or replace while the valve body is off?
If the servo doesn't fix it I will be pulling the trans and rebuilding.
Any tips or advice is appreciated as I'm not familiar with ford's or ford trans.
Old 02-13-2011, 10:44 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: AOD slipping in 4th
Sounds like a worn band. They're usually the first to go on these transmissions considering the band is tiny for the power and weight it has to handle.
If you opt to rebuild, you can put in a lighter servo spring on the OD band servo. It will cause 4th to engage quicker and therefore less wear on the band.
Be careful not to lose the valve body check balls and make sure you know where they go after you remove the separator plate.
I'm not 100% sure on an AOD but you may be able to do a certain number of tweaks on the valve body separator plate and the 1-2 and 2-3 accumulators to increase shift firmness if desired. (google J-mod). It really gets rid of that excess, unnecessary clutch engagement slipping which keeps things cooler and makes the clutches last longer.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
The Following User Says Thank You to Blue)(Fusion For This Useful Post:
consultIII (02-13-2011)
Old 02-13-2011, 06:26 PM
Will look into the jmod, servo spring and other upgrades at rebuild time. Can't get to it untill May so will let you know what I find when its all apart. Time start pricing stuff out I guess.
I will pull off the valve body this weekend and see if anything jumps out. Will the band stay in place when I pull out the o/d servo?
The car has 230 000km and is 23 years old so I can't complain.
Thanks for the advice.
Old 02-14-2011, 12:09 PM
If you remove the servo, the band will have to be pushed back into place with a screwdriver through another hole to put pressure on it so the servo can grab it when re-installing.
Old 03-25-2011, 01:42 AM
finally had time to check this out. Was something easy; (when does that happen) the throttle valve cable retainer had broken off from the throttle linkage. reattached it and everything ok.
Should have clued into the early upshifts and late downshifts. At least no trans rebuild needed...yet
Old Pink Slip New Owner, IDK what to do! help please! Dylano General Issues 0 12-17-2010 02:01 AM
99 MC Gear Slip, Stalls when i slow down sully313 Monte Carlo 3 10-01-2009 11:52 AM
99 civic w/ slipping problems. related to intake? melty '96-'00 Civic 0 07-23-2009 03:17 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
Clutch slipping 4th nickydontcutem Off-Topic 8 03-22-2005 02:23 PM
