Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-12-2011, 02:23 PM
gjdls95 gjdls95 is offline
2002 Ram 1500 Noise During Ignition
A few weeks ago I parked the truck in the garage and the next day I went to start the truck and it wouldn't start. I could hear the fuel pump and the engine was cranking but it wouldn't start. I tried about 5 or 6 times to start in the morning but it wouldn't. A few times while the engine was cranking I would hear a clunk sound which was real brief.
The next day I went back out and tried again and the truck started right up. I started the truck up a week later for work (I only drive the truck a few times a month) and it started fine. I started the truck up today to back it out of the garage to make some room and when I went to start it to bring it in it started to crank and then that clunk sound appeared again. I stopped cranking when I heard the sound and waited a few seconds and started to crank again and the truck started fine.
The truck appears to run fine, no knocking or anything like that just this occasional clunk sound when trying to start the truck.
Any ideas?
Old 02-12-2011, 08:20 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 2002 Ram 1500 Noise During Ignition
Sounds like maybe a little crossfire...spark going to the wrong cylinder.
You might try wiping the inside of the distributor cap and rotor button in case there's crud building up.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 02-12-2011, 08:36 PM
I can try that. This all started happening after I drove through some drifts during a blizzard a few weeks ago. I have driven it about 80 miles since the first time I couldn't start and then it did it today.
Old 07-28-2011, 02:00 PM
mikelj80 mikelj80 is offline
I had same problem I think..engine just turns over but won't start, it was the fuel injectors..found out after replacing the fuel pump.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
Dodge Ram 1500 Sport "Diamond Edition" D-WR3CK Graphic Manipulation 0 02-13-2010 08:57 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 04:24 PM
Instrument Custer Change 2002 Ram 1500 jdb1941 Ram Pickup | Ram SRT10 2 12-18-2006 10:47 PM
2002 Ram 1500 4.7, Weird Sounds condor63 Ram Pickup | Ram SRT10 3 02-25-2005 04:26 PM
