Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 02-10-2011, 11:20 PM
robtthorn robtthorn is offline
ignition coil problems
can any one tell me what would cause the ignition coil to burn up and foul the plugs in # 2& 3 cylinders after driving 10 to 12 miles in a 1997 toyota tercel
Old 02-20-2011, 04:05 AM
killdaggy killdaggy is offline
Re: ignition coil problems
Thats not a big problem. You can fix that by inspecting if its not grounded. Maybe just replace it.
Old 02-22-2011, 09:10 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Toyota coils can fail without technically failing. They can pass the usual resistance tests yet still fail. Why? They can produce a spark, but isn't hot enough to fully ignite the air/fuel mixture. Your plugs are likely fouled due to the incomplete burn caused by a weak coil. Despite this, I'd highly suggest replacing with another Toyota coil because the aftermarket ones don't last very long and they typically do not come with a warranty.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Bad Ignition Coil? Ruley73 Taurus | Taurus Wagon 5 08-04-2010 09:24 PM
97 Safari turns over but won't start - ignition coil wires? icemuncher99 M Bodies 3 05-31-2010 05:03 PM
Ignition coil rain problems jgdfreelance F Series 6 02-07-2010 10:02 AM
need ignition coil and tune up advice jgn Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 07-21-2009 08:26 AM
Ignition Coils on C280 andante147 C-Class 1 06-05-2009 04:57 PM
