Old 02-06-2010, 03:43 PM
jgdfreelance jgdfreelance is offline
Ignition coil rain problems
I drive a 2001 F-150 and I've had to replace ignition coils three times after a rain. It's raining now, the truck's running rough and I'm gonna have to do it again. I know this is an ongoing problem with Ford, my question is, is there a fix for it? Can I use some kind of rain guard over the hood vents? Would that be a waste of time and money? I'm not looking for something pretty, just practical. Thank's much.
Old 02-06-2010, 04:07 PM
danielsatur danielsatur is offline
Re: Ignition coil rain problems
I had to design a rain diverter for my cowl, see www.automotiveforums.com/vbulletin/showthread.php?t=893556
Try using CRC electronic cleaner to clean contaminated COP's instead of new COP's.
Old 02-06-2010, 04:22 PM
THAT is a good idea. Plus, I get to take another trip to Home Depot. Thanks.
Old 02-06-2010, 11:05 PM
dfordski's Avatar
dfordski dfordski is offline
Pay close attention to the tube that wraps around the spark plug. Cracks can allow voltage to jump to ground causing a misfire. The spark plug terminal should also fit tightly.
If a COP coil tests bad and is replaced, future problems can often be avoided by cleaning the COP connector and wiring harness terminals. Corrosion at either place can cause intermittent operation and loss of continuity, which may contribute to component failure. Applying dielectric grease to these connections can help prevent corrosion and assure a good electrical connection.
"Saving the World......One Ford Truck at a Time!"
Old 02-07-2010, 03:00 AM
RahX RahX is offline
So what exactly happens here? Does the rain get under the boot and short the secondary on the coil?
Old 02-07-2010, 09:35 AM
Water would pool in the spark plug boss, short the ignition signal out, causing the misfire.
When the engine gets hot, the spark plug boss pool water would evaporate, the only evidence is a little rust on the COP boot.
Old 02-07-2010, 10:02 AM
Interesting.
Tags
coil , f150 , rain , solution , water
