Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-10-2011, 06:40 PM
smitty782 smitty782 is offline
code 128
Im spending to much time on this site!!!!!!! !Anyway, My 05 Envoy with a 4.2 L is throwing a code 128 temp below thermostat temp what do I do to solve this problem HELP PLEASE
Old 02-10-2011, 08:00 PM
old_master's Avatar
Advisor/Moderator
Re: code 128
Check coolant level, then check the thermostat outlet housing with an infra red thermometer after driving for 20 minutes or so. Should be 195 degrees. If not, the thermostat needs to be replaced.
You have to know how it works,
to figure out why it doesn't.
Old 02-11-2011, 08:12 AM
Re: code 128
Thanks for the info is the thermostat on the 4.2L on the upper hose on the passenger side or on the lower hose on the drivers side
Old 02-11-2011, 07:03 PM
old_master's Avatar
Advisor/Moderator
Re: code 128
Driver side of engine, behind the alternator.
Old 02-12-2011, 03:19 PM
Re: code 128
Thanks found it and replaced it and also found my noise. the guy I bought it from sprayed the belt and pullys with either lithium grease or belt dressing to find out what was making the noise and I checked all the pullys and it turned out to be the belt after pulling the tension pully off several times I finally went and got a new belt...Live and learn anyway thanks for your help
Old 02-12-2011, 06:46 PM
old_master's Avatar
Advisor/Moderator
Re: code 128
The only "fix" for a noisy serpentine belt is make sure the pulleys are lined up perfectly with each other and replace the belt. Did your P0128 go away?
The Following User Says Thank You to old_master For This Useful Post:
smitty782 (02-15-2011)
Old 02-15-2011, 01:13 PM
Re: code 128
Yes code went away after i replaced the thermostat cleaned all pulleys and replaced belt and the noise went away All good for now thanks for your help..Ken
Old 07-16-2014, 09:52 PM
hongdida hongdida is offline
Re: code 128
"Im spending to much time on this site!!!!!!! !Anyway, My 05 Envoy with a 4.2 L is throwing a code 128 temp below thermostat temp what do I do to solve this problem HELP PLEASE"
Same issue here!!! Why?
Old 07-16-2014, 09:54 PM
old_master's Avatar
Advisor/Moderator
Re: code 128
See post #2 above.
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
2001 malibu code 128 r.rogers8 Malibu 3 01-02-2008 02:57 PM
"Check Engine Soon" Code 128 meaning canesrulealways Jimmy 3 12-31-2005 06:27 AM
