Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 12-27-2005, 10:47 PM
canesrulealways canesrulealways is offline
"Check Engine Soon" Code 128 meaning
2001 GMC Jimmy has intermittent "Check Engine Soon" light on. Diagnostic code 128 is what was enter when read. What does this code mean?
Old 12-28-2005, 06:14 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re:
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature
Did you try to swap to a cooler thermostat? If so don't go below a 180.
If you haven't swapped in a newer thermostat, your current one has probably gone bad and is stuck open.
If the latter is the case, considering it's a 2001, I would be nervous about DEX-COOL sludge in the cooling system.
Replace the thermostat and do an acid based flush on your system. I bet one of your symptoms as well is your heat isn't as hot as it used to be.
Old 12-29-2005, 06:58 PM
Re: "Check Engine Soon" Code 128 meaning
Thanks "rlith".
I had already flushed the system with little luck. Changed the thermostat this morning with a 195 degree one and so far no light and the heat's back to normal. Thanks again for the info.
Old 12-31-2005, 06:27 AM
rlith's Avatar
Glad to hear everything is alright...
