Old 02-10-2011, 12:25 PM
joslinm joslinm is offline
Brake problems?
1998 S-10 2 WD
Backed it into my garage last Friday night after work as I always do. Tuesday morning got in the truck, put it in drive, and nothing. Stepped a little harder on the gas and something broke free (like tires were frozen to the ground) and it moved out of the (50 degree) garage, but brakes were definitely on. Pretty sure back ones.
Backed up and went forward a couple times and they seem to be all the way off now. Parking brake never was on.
Any ideas on this??
Also (don't know if related) the last couple weeks the truck whines so loud somewhere in back that you can barely hear the engine. The faster, the louder.
Check rear end for grease level?
Thanks
Old 02-10-2011, 12:58 PM
Scrapper Scrapper is offline
AF Premium User
Re: Brake problems?
i would check e-brake it may be to tight also if you have been going threw snow it has probly got up into your drums and could have frozze and locked brakes? have you had a chance to take wheels and drums off to check?
Old 02-10-2011, 01:07 PM
Re: Brake problems?
I could believe that maybe if the truck sat outside for days, but it didn't
E-Brake is not used, but works fine
Old 02-10-2011, 01:24 PM
AF Premium User
Re: Brake problems?
[quote=joslinm;6869948]1998 S-10 2 WD
Any ideas on this??
Thanks[/quote
then i would take drums off and check brake shoes see if any brake fluid or oil on them. but i think they were just frozze.
Old 02-10-2011, 01:29 PM
AF Premium User
Re: Brake problems?
Originally Posted by joslinm View Post
1998 S-10 2 WD
Any ideas on this??
Thanks
and yes i would check rear end fluid i have a 91 s/10 and the rear end takes tranny fluid. sorry i didn't read enough on your post.
Old 02-10-2011, 03:44 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Brake problems?
My '96 Jimmy took 75W-90 gear oil, not transmission fluid. Check the owner's manual for the right stuff to use, particularly if you have either a limited slip (likely for 2WD) or locking rear differential (4WD).
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-11-2011, 11:01 AM
AF Premium User
Re: Brake problems?
you may be right i know i took tranny plug out because my s/10 is manual and it's tranny fluid in the tranny and i thot in rear end but now i recall it was 80/90 in rear end. my bad..
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 09:14 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 02:41 PM
Braking Problems frehleycomet Tracker 2 03-29-2009 10:46 AM
Brake Problem - Squishy peddle and brake light is on. ekingston Blazer 2 08-01-2004 09:01 PM
1991 Cougar brake problem. Brake Relay? psiege Cougar 1 01-20-2003 06:09 PM
