Old 02-09-2011, 07:01 PM
drchemistry drchemistry is offline
Adding keyless entry to 2007 fleet vehicle
I bought a used 2007 Taurus and discovered (after the deal) that the car doesn't have anti-skid brakes or remote keyless entry. Some sort of stripped-down fleet vehicle. I guess adding an anti-skid brake system would be extremely difficult, but can I add keyless entry? Does anyone know if there's a module or receiver that I could install to gain this capability? I feel like a fool escorting my wife to the car because there's not even a key hole on the passenger side.
Thanks
Old 02-09-2011, 07:44 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Adding keyless entry to 2007 fleet vehicle
Do you have electric locks? if so, you can buy a remote keyless entry module off Ebay for about $35-- for another $20, you can add the remote starter and keyless entry combo.
If manual locks, (no buttons on the doors etc) you can put electric actuators in each door (kit costs about $39- for a four door) and then add the keyless entry with either remote start or just by itself....I've done it both ways- depends on what the owner wants to do.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-10-2011, 11:39 AM
Thanks for the tip. It has electric locks and trunk release. No luck on ebay for an 07, but I'll keep checking.
Old 02-10-2011, 01:23 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
For the cost and amount of wiring needed for keyless entry it's likely better to just go with an aftermarket keyless entry system. Not to mention the range of even the cheap aftermarket systems is generally better than the OEM keyless. Since your Taurus already has power locks and power trunk release (make sure it's a button rather than cable actuated lever) it would be pretty straight forward to install an aftermarket system.
-Rod
Old 02-10-2011, 02:00 PM
brcidd's Avatar
what do you mean no luck on ebay? Search for keyless entry- there are tons of aftermarket systems on there-- and they are not vehicle year specific- will fit any year..
'99 GMC Yukon
Old 02-10-2011, 02:09 PM
Good point! I've been digging around a little. I would need to replace the Smart Junction Box (SJB) with one that supports remote keyless. Supposedly it's an easy switchout. I would need to locate the right SJB, though. This would give me some other auto features as well that were not put on the fleet vehicles.
Old 02-10-2011, 06:16 PM
brcidd's Avatar
Please forget the car specifics--smart junction box is not needed-- everything will come in your keyless entry kit- all you do is hook the wires into the lock and unlock circuits that you already have-- plus a 12v positive wire and a ground wire and an antenna wire- it is really quite simple to do-- I recommend the crimestopper model CS-870 RKE which is on ebay right now for $26. You can go to the crimestopper.com web site and look up the model and instruction manual if you are interested in how it works. (it is under support)
'99 GMC Yukon
Old 11-11-2012, 04:11 PM
hondadad2622 hondadad2622 is offline
brcidd,
I bought one of the same make and model of Taurus. My question is where is the module located in the car that controls the electric doors and windows. I have both and electric trunk. Would you possibly have picture to help me locate it. I spent 30 minutes today going from one side of underneath the dash to the other.
Thanks in advance.
Joe
Thanks from a dumb old dad! Like a bunny with that battery, I have to keep going and going and going on this car!
Old 11-11-2012, 04:56 PM
shorod's Avatar
SHO No Mo
The power door lock functions are built in to the Smart Junction Box (SJB) on the 2007 Taurus. The SJB is located under the dash panel on the driver's side. It appears to basically piggyback the fuse/relay panel.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
hondadad2622 (11-11-2012)
Old 11-11-2012, 05:57 PM
Thanks! I thought I was hearing the trunk relay clicking on this panel. Now, is there a "shade tree version" of what wires do what coming out of this module? I really appreciate this.
Joe
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
Adding keyless entry Tillman Intrepid 3 04-03-2006 01:41 AM
Adding keyless entry '86 camry j1mb0 Camry/Camry Hybrid/Vista 3 01-13-2004 07:48 PM
Adding keyless entry Tillman Intrepid 1 07-27-2003 12:06 PM
