Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-09-2011, 02:40 PM
simreal simreal is offline
Send a message via ICQ to simreal Send a message via AIM to simreal
2002 Explorer - Heat/AC Vent flapping
I just bought an 02 and its in great shape.
I am having one odd problem. When the temp is set to either hot or cold all is well. If I select a temp in the middle somewhere there is a valve/door in the dash somewhere that appears to slap open and then close about every 3-5 seconds. If I turn it all the way hot or cold it will stop.
Turning the fan speed up or down doesnt seem to make any difference. Neither does switching between defrost or partial mix floor/vent.
Anyone have any idea why this might be doing this?
Old 02-14-2011, 11:12 AM
bigryry bigryry is offline
Re: 2002 Explorer - Heat/AC Vent flapping
Probably your blend door motor. My 2002 would do the same thing. I would hear the door trying to move but couldn't. It wsa stuck on a/c and wouldn't heat. Which was fine untill the snow started to fly.
The part is super cheap and it is due to a a little plastic gear stripping out next to a $2.00 motor. The whole assembly is like 30 bucks i think and the labor was like $600.. They had to take the whole dash out and the center counsil out. Very labor intense.. Some you can get to by taking hte radio out, but not the 2002 from what i was told.
Ford wanted $1,200 to do the work like 3 years ago.. Hope this lead you in the right direction
Old 02-14-2011, 11:20 AM
brcidd's Avatar
brcidd brcidd is offline
If yours is an early build '02 (check driver's door sticker) then this may apply
http://heatertreater.net/Ford%20Explorer%2096-02.htm
kit is for sale on ebay
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-14-2011, 06:16 PM
Mine was a late build 2002. Mine was built Sept. 2002.
The guy i took it to said the same thing, ford moved them around alot and it was a common problem.
I replaced my wife's blend door motor on he 01 windstar..
Good luck!!
Old 02-17-2011, 10:24 PM
crtravis55 crtravis55 is offline
I just started having the same problem in my 2003. Started getting the flapping only on full heat but now on all temps and get no heat at all out. Has anyone tried fixing it themselves or have an idea as to how much time it takes?
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 01:22 PM
98 explorer heat/ac streetrodd37 Explorer | Explorer Sport Trac 2 01-31-2010 08:48 PM
99 Windstar - door in heat/AC box flapping. What's up w/ that? MasterChief Windstar 2 09-22-2008 02:17 PM
2002 Sable heat/ac problem? notafan Sable 1 02-17-2007 10:16 PM
1988 XJ heating/AC vents not working pdlee Cherokee 10 07-15-2004 10:01 AM
