Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 02-08-2011, 11:40 AM
kchew kchew is offline
replaced timing belt - now p0340 code
I replaced my timing belt on a 2000 dodge stratus 2.0L and was very careful to make sure everything was aligned when I put it back together. When I was done it ran great for about 10 minutes then quit and wouldn't start back up. I pulled a p0340 code and replaced the camshaft position sensor since it was a cheap part but still it won't start. Any suggestions on what could be causing this problem? My wife needs her car! Thanks for any help/suggestions.
Old 02-08-2011, 12:22 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: replaced timing belt - now p0340 code
check your connector for the cam sensor; make sure it's OK. A possible other cause is the tone wheel on the cam gear is bad. When you replaced the t-belt, you didn't by any chance place a magnet near the cam gear did you?
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 02-09-2011, 06:51 AM
the tone wheel on the cam gear is a calibrated sensor that the cam sensor uses to determine the position of the #1 cylinder when it's at TDC. Placing a magnet near the tone wheel now throws off the calibration. You'll need a new cam gear, which means, take the t-belt back off.
Replaced timing belt now no spark AutoguruGT '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 04-01-2009 12:31 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
Replaced Timing Belt Now Won't Start goodtimepete 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 04-14-2005 04:13 PM
