Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 02-04-2011, 05:04 PM
cgreygoose cgreygoose is offline
where to find tranny dip stick 98 TC?
I've replaced all the fluids and I wanted to check the transmission fluid level and I can't seem to find it. It's either hidden or I'm blind as a bat.
Old 02-04-2011, 05:25 PM
AutomediaJoe AutomediaJoe is offline
Re: where to find tranny dip stick 98 TC?
I found the answer on another forum:
KManiac
03-21-2006, 10:51 PM
I just changed the transmission fluid in my father's 1997 Town [COLOR=blue ! important][COLOR=blue ! important]Car[/color][/color], so I should be able to help you with this one.
The transmission oil dipstick is located between the back of the [COLOR=blue ! important][COLOR=blue ! important]engine[/color][/color] and the firewall, to the passenger side of the centerline (from front to rear) of the engine compartment. The dipstick and fill tube are painted black. The top of the dipstick is a round wire loop. There is no labeling or fancy pull handle like the oil dipstick. Open your hood, walk to the passenger side of the engine compartment and look behind the [COLOR=blue ! important][COLOR=blue ! important]engine[/color][/color]. You should be able to see it. Be careful when you pull it out. There is a metal lipped edge on the top of the firewall, and I scraped the back of my hand several times while checking the fluid level.
The dipstick in my father's [COLOR=blue ! important][COLOR=blue ! important]car[/color][/color] was easy to find since his car is painted white (white car, white firewall). If you have a black or dark colored car, it will be harder to find the black dipstick. It's there, just get a flashlight to help you see.
I hope this helps.
If this doesnt work check the owners manual
Old 02-04-2011, 07:25 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
That's correct, the Transmission oil dipstick is located at the back between the engine and the firewall, it has a black looped handle and close to the center of the engine compartment.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-04-2011, 08:07 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Remember to check the ATF level with the transmission at operating temperatures and with the engine running, in Park. To get the fluid up to operating temperatures (150-170 degrees F), it will take atleast 20 minutes of city driving. Longer if it is below 50 degrees F outside.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 02-05-2011, 05:14 PM
i can't believe I missed it. yes, I found it and was able to check the fluid and top it off a little. I also have a 62 Lincoln Continental Conv. which is a lot easier to work on that's for sure. the 98 TC runs well but it shudders a bit when I'm accelerating and once I'm up to speed it rides nice. it does blow some smoke. not sure if it's cause it sat for a while, bad gas etc. and/or the SeaFoam & Lucas products that I've added to the oil & gas. I've also used CRC MAF cleaner too. All of the fluids have been changed and they all look good now. This is a very very comfy car to ride in to be sure. I have a mechanic buddy who is supposed to come by in the next few days and I would like to point him in the right direction since I'm paying him time & materials. thanks for all your help.
Old 02-06-2011, 04:26 PM
Smashcbn Smashcbn is offline
Don't feel bad. I couldn't find it right away in my 2003 Town Car. It's in the same stupid location. Some times you would think they could make some changes when they change the body styles.
Old 02-06-2011, 04:28 PM
They did change it in either 2003.5 or 2004. It is in the same location, but sits much higher and much more readily accessible.
Where is the auto tranny dip stick ? 05', also is there a cabin filter ? kool7 Tacoma 0 02-02-2010 10:15 PM
NEED HELP finding dip stick! 67caddy Deville 2 10-18-2007 09:29 PM
Can't find the oil dip stick? Swin72 Rodeo | Passport | MU 2 05-16-2005 03:24 PM
where is the engine oil dip stick located in a 2000 contour 2.0L poetry Contour 1 04-30-2005 06:24 PM
Where can i get a dip stick for a 95 Gs-t Eclipse?? bmoreboy52 Off-Topic 3 11-03-2004 05:10 PM
