Old 02-03-2011, 12:22 PM
rkvons's Avatar
rkvons rkvons is offline
Keyless fobs that don't work.
Hi all,
I had a couple of keyless fobs for my '98 pontiacs that seemed to stop working. I went online and ordered new buttons and cleaned the pads on the Printed Wiring Board (PWB) and even glued some tin foil on the bottons and I could not get my fob to work consistently. It would work about one out of every 4 times and was getting worse. Well, I finally determined the cause. I looked at the Integrated Circuit (IC) under a microscope and noticed that some of the pins had bad solder connections to the PWB. Evidently, when the buttons start to wear out, it forces you to press harder on them, which flexes the PWB and breaks the pin solder connections. So, if you are having this problem, touch up all the pin connections from the IC with a soldering gun.
Old 02-03-2011, 01:24 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Keyless fobs that don't work.
Good find!
Chances are the fix works for other models, and even other brands as these things are usually made by a 3rd party
Old 02-03-2011, 02:09 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Yeah I agree, thanks for the info. Mine seems to be doing the same thing. Maybe I should just buy a new remote.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-04-2011, 07:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
But not a flaky third party or aftermarket brand Tim. Stick with the OE GM keyfobs.
Timeslip 08/12/06
AF Community Guidelines
