Old 02-02-2011, 12:24 AM
tmct14mrtn5 tmct14mrtn5 is offline
Grand Am stalls
Recently aquired a 2000 Pontiac Grand AM. In the past two weeks the car shut down while driving. The ABS, Trac Off, and Service Vehicle soon light would come on, then very shortly after the car would stall. After I get the car to the side of the road I would take the key out of the ignition, then put it back. The car would start right up with no problems for a few days, then it would happen all over again. Any input would be appreciated. Thanks
Old 02-02-2011, 12:56 AM
thephantom1492 thephantom1492 is offline
Re: Grand Am stalls
I'ld start by checking that all the fuses are well seated, that the battery terminals are very tight. You have 3 fuses block: one under the hood, one on each side of the dash.
Having the code read could help.
Old 02-02-2011, 02:05 PM
skeeter123 skeeter123 is offline
Re: Grand Am stalls
When you get the codes read, bear in mind that the freebie code readers used by the auto-parts places typically can't read the GM ABS or transmission codes; so they'll say "No codes!". Find someone with a code reader/scanner that can do ABS codes, i have the Equus 3160. That will tell you if its a wheel bearing/sensor setting off the ABS/Traction control lights, or whatever.
Old 02-02-2011, 09:09 PM
Re: Grand Am stalls
I doubt it's an abs issue. The ABS/Trac off is just a side effect.
If the engine ain'T running right then the abs and traction control (which is made by the abs system) shut off.
Old 02-03-2011, 12:57 PM
muff34 muff34 is offline
Re: Grand Am stalls
Is there an aftermarket remote start system in car??
Life Is A Highway ,Enjoy The Ride
Old 02-03-2011, 02:27 PM
Re: Grand Am stalls
If you think about the passlock bypas module, it can't be it, it would just make the security light turn on.
As for the other wires, it's in parallel, so even if defect it shouln't do anything. Unless really, really badly installed: cut wires, twisted, not soldered. But it would normally cause other issues too, not so repeatable...
Old 02-06-2011, 07:11 AM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
Re: Grand Am stalls
sound similar to an intermittant crank sensor or cam sensor. GM trucks had a si ilar issue about the same time frame. I also had an '89 Cavalier that had the crank sensor issue.
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
96 grand am see 2.4 stalls from idle after restarting when warm john murman Grand AM 2 11-29-2010 05:55 AM
2000 Grand am se...bad idle and stalls weis_01 Grand AM 3 09-19-2010 11:50 PM
2002 GP/GT Troubleshooting Stall/Rev Engine DreamRiver Grand Prix 5 05-17-2010 09:53 AM
Phantom stall/tach drop '97 Grand Caravan Georgetime Caravan | Voyager 1 02-11-2009 02:21 PM
97 Grand stalls when in gear theythem Grand Cherokee | Grand Cherokee SRT8 3 02-02-2005 01:50 PM
