Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-01-2011, 04:08 AM
Christopher209 Christopher209 is offline
Swapping Motors
I Have A question I have a 1990 integra Ls 4 door. The car is completely stock. I want to put a vtec motor in it. I dont know to much about cars. Will i have to replace alot of parts to drop a vtec in it? The reason im asking the car blows white smoke and the mechanic says i need a new haed gasket its going to cost no more then 700 parts & labor. So im thinking it might be better to get a new engine thats faster. But not be worth it if i have to change alot of other parts Thanks.
Old 02-01-2011, 05:48 AM
snshddog snshddog is offline
Re: Swapping Motors
In most cases it is simply replace the engine, wire harness, and computer. Alot more work than a head gasket but when done right is worth it. There must be a good tuner club or custom shop that can line you up with the right parts and/or do the work. You need to decide first how big you want to go. There are so many kits available you can almost put any honda or acura engine in it. You might want to price around a bit first. 700 seems quite high for just a head gasket job even assuming they have head machining in there too.
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
help please !! motor build question!! Derrick12556 Mirage 2 12-27-2009 05:31 AM
Lemans motor swap xxGriffonxx LeMans 4 10-27-2009 08:28 AM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
