Old 01-30-2011, 06:14 PM
waldenhughes waldenhughes is offline
Bravada 2000 intake manifold
HI
Ok looking for help
Ever thing was fine with the car ran well before I started work on the car apart from the intake manifold gasket was leaking coolant out side the engine
I did my intake manifold gasket, and when I finished it was running rough at lower rpm and code P0300 can up
Fuel pressure was ok at 60psi I think that’s ok anyway?
I changed my
Spark plugs
Spark plug leads
Distributor cap
And rotor
Even had a different coil
And still did the same thing
So I thought to myself I must have done some thing wrong so I got another gasket set and redid every thing again made sure every thing was torque down right ,
And when I finished again the same thing ,code P0300 comes up and it runs rough at lower RPM I can drive it ,it runs(but roughly) but every now and then the service light flashes and code P0300 comes up
Any help would be great I am about to pull all my hair out and I do not have to much left as it is
Alex
Old 01-30-2011, 09:17 PM
old_master's Avatar
Advisor/Moderator
Re: Bravada 2000 intake manifold
Double check the spark plug wire routing. Very common mistake to swap cylinders 1 & 3 on the cap, which will make the engine run poorly.
You have to know how it works,
to figure out why it doesn't.
Old 01-30-2011, 10:11 PM
hi thanks
was thinking that to but check and they are in the right order
is there a way to check to see if 1 of my jets are blocked ? a easy way that is lol even like i say before i started this every thing was working fine apart from leak that is
Old 01-31-2011, 01:40 PM
old_master's Avatar
Advisor/Moderator
Is P0300 the only DTC that's showing up? P0300 is "random cylinder misfire" which means more than one cylinder is misfiring. Does your scan tool have access to the misfire history file? If so, what cylinders are misfiring?
Old 01-31-2011, 04:22 PM
Hi
i have a Actron PocketScan Code Reader CP9125 ,
and to be turthfull i just know how to get codes, do not know what or how to do anything esle even if it does anything esle lol
as for the code its shows 2 codes both P0300 think 1 P0300 is because it has happened and the other Other P0300 is that it's still happening or some thing
Alex
Old 01-31-2011, 04:55 PM
viggy58 viggy58 is offline
might have missed the distributor by a tooth when you re-installed it.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
old_master's Avatar
Advisor/Moderator
If the distributor is off a tooth it will set P1345.
That's an entry level code reader. When it comes to diagnostics, it tells you what "ball park" you're in, but not what section or seat
Did you replace all of those parts at the same time as the intake gasket, or when it idled rough after replacing the gasket?
P0300 through P0306 all have to do with engine misfire. 90% of the time it's caused by a fault in the secondary ignition system: Spark plugs, plug wires, coil wire, distributor cap, rotor and ignition coil, all of the things you just replaced. These things are real fussy when it comes to secondary ignition parts, what brand of parts did you use?
Another thing that can set a P0300 is low fuel pressure and/or low volume. Make sure the fuel filter is not restricted. Key ON, engine OFF, fuel pump running: pressure must be 60psi to 66psi and must remain above 55psi for 3 to 5 minutes after the fuel pump shuts off.
Old 01-31-2011, 05:09 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Check Not Only the order of the wires on the Distributor cap, but follow each wire all the way to each plug. Once you get down there around the steering box, the wires can get hard to see and follow, same for the other side.
Did you use an AC-Delco cap? It is not impossible that you got a bad cap. Other brand name caps simply won't cut it. I would also double check the Plug gaps.
As a last resort, try putting your old cap back on. Although many things can cause a P0300 Code, My experience with this code is almost always with the cap.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 02-01-2011, 08:16 AM
Hi
Thanks for all the help
I started having the problem after I changed the gasket so I changed every thing 1 by 1
As for the part they are from advanced auto parts after market parts but what are the chances that the new parts would do the same as the old parts so do not think it's them or am I wrong?
I have started to think it's the spark looked at it again and its more orange than blue so may be a weak coil? Or Ignition Control Module?
Going to get an inline spark tester as soon as I can, and meter out the coil
Alex
Old 02-01-2011, 04:14 PM
old_master's Avatar
Advisor/Moderator
The chances that a replacement part has the same problem as the old one is extremely slim. Not only does it get expensive when you guess, but you run the risk of either introducing a new problem, or installing a faulty part, that's where proper diagnosis comes into the picture.
If the problem showed up after the intake gasket replacement, the chances of the ignition coil or module going bad during the gasket replacement is also extremely slim. I'd start by looking for a vacuum leak. One of the gaskets may not be sealing properly, (including the plenum gasket). Make sure all of the vacuum lines are good, and connected properly. Double check the fuel injector electrical connector: the pins and sockets are fragile. Also, check for blue, not orange, spark at all of the spark plugs with the inline spark tester. Post your results. Don't throw parts at it until we get it diagnosed
Old 02-01-2011, 11:38 PM
Hi
ok it may be afew days before i can get to the store and get the tester
good thing i have my bike LOL
i'll post here when i have tested the plugs
thanks again for help
Alex
Old 02-05-2011, 04:45 PM
Hi
Ok here I go again lol
Got the spark tester and had a good spark
So went to auto store to see if they could pull any thing from the computer, but just same thing I had P0300,
We test the ignition module while I was there that tested ok as well, we tried a new coil just incase no different,
HHHHeeeeeellllpppp lol
Alex
Spayed throttle body cleaner all around and did not change the engine any
Old 02-05-2011, 05:40 PM
old_master's Avatar
Advisor/Moderator
Did you use AC Delco plugs # 41-993 with a gap of .060" if not, what brand and part number did you use?
Old 02-05-2011, 06:50 PM
ok i think i may have it
i took the T/B and every thing off ,pull each injector leg out of there holes and put them all on a bit of paper ,put the fuel lines back in and turned the engine over ,
out of the 6 injectors only 4 seem to be working 2 did not have any gas coming out of them
would this account for my problems ?
if so can they be clean or do i have to replace them ?
thanks Alex
Old 02-05-2011, 06:53 PM
old_master's Avatar
Advisor/Moderator
Absolutely could be the cause. What cylinders were not working?
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
2000 intake manifold jase386 LeSabre 2 09-30-2007 10:15 PM
