Old 09-28-2007, 03:20 AM
jase386 jase386 is offline
Send a message via AIM to jase386
2000 intake manifold
is there as much problem with the 2000 and newer models as there were on the 94-99's? ive lost a little bit of coolant, but it could be from a small leak i saw. even though im a little low, the level hasnt changed in 2000 miles.
Old 09-29-2007, 09:36 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 intake manifold
Some but not as much as the '95-'98 SII 3800 engines. Common problem is not the plastic UIM with EGR stovepipe damage but the UIM gasket. Since you have visually confirmed a leak then that might explain any coolant loss. Where exactly is the coolant leak?
Timeslip 08/12/06
AF Community Guidelines
Old 09-30-2007, 10:15 PM
guess i should have mentioned that the leak looks like it may be from the drain cock instead of near or around the manifold
